Tesla's Battery Pack Costs Are Cheaper Than You Think -- The Motley Fool
Something that I have not seen anyone talk about is Bereisa's (he should have an excellent idea) estimate of $215/kWh for GM's pack related costs, $215 - $145 =
$60 = 41%!
Some implications of that:
1. I suspected a high number because GM chose to reveal cell costs rather than pack costs but wow! Battery cell costs are a huge percentage of EV costs. How can GM even dream about being competitive with Tesla with ~40% pack related costs?
2. My earlier
conservative cost estimates for Tesla's current packs ranged from $165 per kWh to $190 per kWh. Even if you use $190 - 35% (30% GF + 5% due to moderate cell improvements) Tesla's pack costs will be
a maximum of $123.50 per kWh, all of these figures are conservative. So a 60 kWh pack will cost Tesla under $7,410 and will cost GM about $12,900. Tesla's actual pack costs will probably be about 50% of GM's, or close to $100 per kWh.
3. I don't think that Bereisa was being dishonest. I think that he and GM smugly believe (or believed
) that they have excellent pack prices.
I'm in the process of converting my big pack cost post to a pdf, and I'm updating it at the same time. I think that the following is an important update/correction:
Larger Cell Format:
I have wondered why I have seen statements that the new larger cell format would lead to 30% increased pack energy density.
It will not. But it will lead to an across the board increase in total pack energy of by 7.6%, plus
the “moderate improvements” (5-8%) due to improved cell chemistry,
so the total increase will be at least 12-15%.
I think that the source of the 30% confusion is the following statement by EM:
Elon Musk - Chairman and CEO
Tesla seems to have decided to use 20700 cylindrical cells with dimensions 20 mm x 70 mm instead of the 18650 that is 18 mm x 65 mm. Because all of the Tesla packs consist of modules, of cells that are vertical, one layer deep, the limitation of the number of cells, in their packs are the length and the width.
The area of a circle is pi squared x the radius. So we need to compare pi x 9 squared vs pi x 10 squared. For simplicity we can eliminate pi because used the same multiple won't effect the relative percentages, so:
9 squared equals 81 vs 10 squared equals 100, so the smaller cells have 81% of the capacity of the larger cells,
which is a substantial difference.
But the area required for 100 of the 18 mm round cells is a square, 180 mm x 180 mm. In that area you can only fit 9 x 9 of the 20 mm cells (81 cells) . So only 81% of the larger cells will fit in the area required for the smaller cells.
In other words the net increase in the pack capacity, due to the larger diameter of the cells will be close to zero.
But for the height we have 66mm vs 70 mm (5/65) is 7.6%.
Which means that by switching to cells with the new format all of Tesla’s pack capacities will increase by 7.6%. So 70 kWh packs will increase to 75.3 kWh. That does not include the “moderate improvements” (5-8%) due to improved cell chemistry. For a total increase of 12-15%.
Another reason they are increasing the cell size is to reduce the cost, probably largely due to the decreased pack complexity:
JB Straubel - Chief Technology Officer
