So.........chicken for lunch is good idea?Right- you are, again, claiming something nobody ever actually said.
Not sure why you keep doing that other than you know you have no actual argument to make so you have to invent strawmen instead?
Nobody knows why you keep mentioning it since it's not relevant at all.
I can describe the crime of murder in the second degree without using the word murder for example, but you can then look up the requirements for murder in each degree and determine the actual crime I was describing. Same with many many other things where you can describe a level or capability of a thing without using a specific word that might define that thing.
This is not a hard concept but you somehow get that completely wrong too.
Tesla is a describing the planned capabilities of their system.
If you take that description, and look up the SAE levels, you find that the minimum level that fits their description is L4.
Somehow you get lost, badly, between those 2 sentences over and over again.
And yet has all the info needed for what I just explained above, assuming you actually understand:
What they said
and
What the SAE levels say.
This one you get even more wrong.
Not even L3 requires "supervision"- it requires being prepared to take over when prompted- on every drive you take. That is a DIFFERENT action than the supervision actions folks using the current L2 FSDb system must engage in (they ALSO have to be prepared to take over at any time, but also have to do additional actions on top).
Regardless of which, requiring ANY action violates what Tesla actually wrote, regardless of what action that is.
And, again, the minimum SAE level that requires no action of any kind is L4.
Because it's factually correct.
Refusing to understand facts seems to be a big issue with you.
Maybe try reading it even once and get back to us?
If you did you'd realize you were wrong about this entire discussion, and admit you can't find a single thing in there that disagrees with anything I've said.
(If you COULD find such a thing, you'd have cited it--- instead you keep making up strawmen instead of making up a valid argument)
CLEARLY!
Literally your entire argument is incorrect.
Anything below L4 in SAE requires action by the person in the drivers seat on every drive using the system. The chart is a summary that shows you, circled in red, the action required with every use of the system at L3. Looking to the left you see even more actions required at lower levels.
Tesla said their system will be capable of drives requiring no action.
Thus the system can not be L3 or lower. The lowest level their system could be under SAE is L4. Possibly L5 but THAT we lack enough info from Tesla to determine.
That's it.
That's the entire argument.
You've wasted pages of posts failing to grasp it, providing literally nothing to actually dispute it, and making up thing after thing nobody said to debate instead.
Please adhere to your Avatar and break this up into multiple quotes and reply to each sentence and get in the last word.
Would V11 be an acceptable way of picking up chicken?
Does using V11 instead of L4 to get chicken result in a less tasty bird?
Most important: Which comes first: V11 or the egg of a chicken that I want to eat and has that egg been laid yet?
