Rear side door unlatching
AllieS
New Member
Jun 11, 2021
3
0
Palo Alto, Ca
Rear side door on my 2015 Model S unlatches when you turn the car on and again when you turn it off. By unlatches, I mean that it is fully unlatched and ajar by a small amount…but enough that if you just pull on the door without touching the handle, the door will open. Any ideas on fixing this from home or the screen? Thanks!
Did you ever solve the problem? The rear driver-side door on my 2018 S is unlatching itself, and I also concluded it's the controller.
I had the same problem with a 2021 Model S refresh. Turned out to be when service adjusted the handle the hall effect was misaligned. Service fixed it quickly
