Sad
Fun to play around with numbers :smile:. If I assume flat higher torque, i.e. linear power progression, until 40 km/h (instead of the current 65 km/h), then flat 300 kW power between 40 and 100, I arrive to a 0-100 km/h time of 3.4 seconds... which is exactly what Tesla is quoting. Replacing 40 by 65 yields 4.2, which is not too far from what the P85 can do...
The assumption behind the 40 km/h peak torque is that the higher torque produced by the two engines allow peak power to be reached much quicker.
My simplistic math:
Kinetic energy at 100 km/h: 0.24 kWh
I assume an average of half the power between 0 and 40, i.e. 150kW, which requires 0.93 seconds to make it to 40
I then assume a constant power of 300 kW to move from 40 to 100, i.e. provide 0.20 kWh of kinetic energy, that will require 2.45 seconds.
So maybe the car can make it by having peak 350 kWh (what my current MS is rated at in Switzerland), after accounting for losses.
My simplistic math:
