Braking suppliers such as Bosch introduced electrohydraulic braking systems years ago as the initial foray into brake-by-wire. Bosch worked with Daimler in developing the Sensotronic brake system, introduced on the Mercedes SL in 2001.
That system replaced the conventional master cylinder with a hydraulic high-pressure reservoir and a piston pump driven by an electric motor. When the brake was applied, an electronic control unit calculated the desired brake pressure on each individual wheel, for improved stability.
But there were technical difficulties, and Mercedes recalled some 2 million vehicles with the system in 2004 and 2005. The auto maker eventually dropped the system. Toyota is conducting a similar brake recall.
The Mercedes recall illustrated that brake-by-wire may need more development time, Steiger says. As a result, the new iBooster still integrates with full hydraulic braking and a conventional master cylinder.
“We said we always need direct control from the driver so we developed the iBooster, which has a direct link between the pedal and the master cylinder,” he says. “So if something goes wrong, if there is a failure, we still have the ability to brake by your own foot.”
