I would love to have an 85kWh Powerwall instead of that much money.
What are the logistics of this and does anyone know of a company or person who could harvest the battery pack
and create a home battery system for me in NorCal? Or does it even make sense?
In case this could help you, I noticed this company called '
Sigineer Power' making specifically designed DC/AC inverters:
Inverter manufacturers of whole house inverter for home use. Low frequency Pure Sine Wave Inverter Charger, Hybrid Solar Power Inverters.
www.sigineer.com
(You migh also look at '
Schneider Electric' which is a very well recognized solar systems company, they might be related, not really sure.)
Tesla Battery Compatible Inverter works with module of Model S X 3 | It converts DC To AC and it also built with a AC battery charger. The customized voltage setting to avoid over charging & discharging. It offers ideal backup power with tesla battery for home or solar systems.
www.sigineer.com
Sigineer Power’s Tesla Battery Compatible Inverter works from DC to AC with Tesla Battery.
It has voltage settings tailored for Tesla Model S , Model 3 and Model X battery modules.
Our inverters don’t interface with the propietary Tesla battery pack BMS,
users have to jailbreak it or use a 3rd party BMS and set the battery voltage range to suit our inverter.
For these models, the battery type selector position of “9” is customized with a special battery algorithm
to work with Tesla Model S and Model X lithium-ion battery modules.
Inverter 24vdc to 240vac built with full bridge circuit, 6KW rated power with 18KW surge, 80A battery charger, 50 / 60 Hz dual output.
www.sigineer.com
Model #: APC6024D
This 6Kw Tesla battery inverter converts 24vdc from Tesla Model S modules to 120V 240vac split phase.
It is built with a
battery charger with a charging algorithm tailored to the Tesla Model S module,
it also works with the lead acid, AGM, GEL batteries.
15000 Watt Inverter outputs 15KW Pure sine wave power from 96v to 120/240V or 115/230V. Designed for Tesla Model 3 S Battery Modules.
www.sigineer.com
Model #: HP15096D
This 96Vdc 15000 watt off grid pure sine wave inverter charger is tailored with voltages settings
for Tesla Model 3 battery module. It converts 96v to 120/240V 60Hz split phase.
Pure Sine Wave Power Inverter with Power Factor Correction Battery Charger (PFC Charger)
www.sigineer.com
The power output of the Grid Tie Inverter varies with the sensed frequency of the waveform provided by the battery-based inverter. SMA defines this as Frequency-Shift Power Control (FSPC), Schneider calls this Active Frequency Shift Power Curtailment (AFSPC) and SolarEdge presents this as Power...
www.sigineer.com
Regarding some company using Tesla batteries, from the Testimony webpage, you might find some companies working on Tesla batteries conversions:
www.sigineer.com
Sigineer Power offers OEM & ODM inverter services. It is open to cooperate with companies in need of specific products & specialized in product development, manufacturing & testing.
www.sigineer.com
