oh, I like that. Really wish we had some form of advanced diagnostics.
As do I.
It is a challenging UI question. If their estimate has an 10 mile potential error and they hit 0 at the earliest point they protect more drivers from themselves, but build up the legend of the buffer. If they set it for anything else, once in a while someone is going run out at a positive number. Perhaps going to "---" once you get to a certain point is the best compromise.
Unfortunately voltage does not tell the whole story of SOC. And most people will not know how to analyze voltage. That's best reserved for a "advanced" section of the UI.Novel idea - how about stop displaying miles when it dips too low, but allow us to see the pack voltage? No calculation involved, just empirical data.
I started a thread about this last year. While Tesla never implemented a "heater-on" indicator like I would prefer, someone pointed out that the vent location indicator will show an arrow at your feet when the heater is on and that's how I know when it's on.
Here's a link to the thread:
http://www.teslamotorsclub.com/showthread.php/35078-Heater-on-off-Button
I've gotten it down to 2%, and I remember the power being limited, but I'm sure I was doing around 65mph (don't recall the speed being limited to some odd value)
Cold temperature is a variable. When a cell is cold, the voltage drops and that drop can damage the cell if it reaches below the minimum point (2.5V per cell). Thermal management should mitigate that, but it depends on how cold the outside is and how long the heating system has been running (cold soak).Last winter, I got a power reduction, a message to charge ASAP and something about the battery being cold at 20% SOC. I had just come off the highway after an hour or so of driving and the ambient temps were around 20F. I think there are a lot of variables that the car considers.
At low battery levels I have observed a reduction in available POWER (yellow dashed line on the power meter) but no "speed limit".But no associated maximum speed reduction, correct?
I agree with whomever pointed it out first, the OP's 40mph speed reduction is odd...
There's been lots and lots and lots of discussion about this, but I don't believe Tesla ever once said anything about a "reserve" below zero.
I've seen claims that this chart came from a Tesla deck, but I'm not sure I believe it. I know it used to be posted here often.
That chart is totally incorrect, for the record.
To protect the battery. Taking a large amount of power out of a low battery will heat up the individual cells and cause microcracking to occur shortening battery life (perhaps dramatically).
Hi, @gavine, thanks for the pointer to th thread, I actually read it once. However if I set AC to say 78F and outside is 77F would the AC change the vent to "foot"?
Actually, no, the car does not limit speed when it gets close. That is unusual behavior. I had no trouble driving above 65 MPH with less than 10 miles remaining. An energy limiter kicks in on the high end, which limits your acceleration, but not your speed.
Because in your scenario, the car's heater is turning on. When the car heats, it diverts air flow to the lower vents. When cooling, air flow diverts to the top vents.
I wish new drivers would be educated on the buffer principle. Then again, maybe it's too hard to figure out that you need to watch, not your range, but what you have extra.
If I have a hundred mile trip to make, and give myself 130 miles of range before driving off, ten miles down the road I am able to tell how my range is going.
I should have 90 range and 30 buffer, or 120. If my buffer is down even 3 miles, I need to slow down a couple miles an hour. If my buffer is growing, I can pep it up. When you get to the destination, you want to still have those 30 miles, but IF you have trouble, high winds, detours, it won't be near as scary, because you have your buffer.
It makes sense to limit the power from a nearly depleted battery but a speed limit would not be of any use... you could be going downhill in regen mode.
