There's no reason a UMC couldn't be plugged into a properly wired 15-60,.
Does the North American spec UMC support 3-phase connections? I thought only the European charging equipment was designed for 3-phase...
No, it doesn't. I don't know what kind of hack would be required to be able to use a legit correctly wired 15-60, or if it's even possible.Does the North American spec UMC support 3-phase connections? I thought only the European charging equipment was designed for 3-phase...
"No reason"? Well, two reasons come to mind:There's no reason a UMC couldn't be plugged into a properly wired 15-60
1. Tesla doesn't make a plug for a 15-60, so you can't just plug it in, without building some other third party pigtail adapter to reroute wires to some other plug that Tesla does make.
2. The North American UMC can't use 3 phase, so the best you might be able to do is get one of the phases and ground and treat that as if it was a single phase by use of a separate pigtail as mentioned above.
Uh huh--exactly. And that's quite different than just "plugging in", as you originally suggested.Of course you'd have to build an adapter. It would use TWO of the phases and ground to get either 208v or 240v at 60a.
If you say so.Uh huh--exactly. And that's quite different than just "plugging in", as you originally suggested.
Right--I did forget that's the regular way commercial buildings supply the 208V as a substitute for 240V.and at better than the 120v which you said was the best you could do, I might add.
so did they ever give you the corded, 40A-capable mobile connector? Or were you stuck with the downgraded 32A connector?Thanks! I didn’t realize the “corded” 40A charger didn’t have any other adapters.
Don't be like that. It's not a lie. It has things that are better and worse:Then they lied and said the Gen2 32A connector is an upgrade over my Gen1 40A connector.
I see your logic, cheaper, less capable, but has some safety features the old one didn't have, so it's an upgrade. Using that same logic, I assume you'd consider a 2014 Nissan Leaf SV an upgrade for your 2014 Model S85 - it is cheaper, less capable, but it has surround vision which is a safety feature (more people have scratched up their cars or even pulled their front bumpers off of their S than people melted the 40A plug), right?Don't be like that. It's not a lie. It has things that are better and worse:
Gen2 does have temperature sensing circuits inside the plug heads that can detect if the outlet is getting hot. There had been a LOT of cases of people having melted outlets and melted plugs from loose wiring connections making the wiring at the outlet overheat from the old Gen1 plugs that were running at higher currents, but didn't have to safety systems to detect if something was going wrong there. So that is an improvement, and yes, is an "upgrade".
Gen2 has a lower maximum current capability. So yes, that part is worse and is a "downgrade".
So different people might look at that different ways, with slower charging speed but improved safety possibly being considered overall better.
Don't assume what I think. People evaluate the differences in features, and people value some things higher than others. I've been driving cheap econo cars my whole life, so that surround view safety thing just isn't very important to me versus range. But for some people that might be different.I see your logic, cheaper, less capable, but has some safety features the old one didn't have, so it's an upgrade. Using that same logic, I assume you'd consider a 2014 Nissan Leaf SV an upgrade for your 2014 Model S85 - it is cheaper, less capable, but it has surround vision which is a safety feature (more people have scratched up their cars or even pulled their front bumpers off of their S than people melted the 40A plug), right?
So what you're saying is there is no absolute definition of what is an upgrade or a downgrade. Anything could be considered an upgrade over anything, depending on one's priorities. So even a bicycle could be considered an upgrade to a P100D, for those who value open air the most and maybe live somewhere where there are no chargers.Don't assume what I think. People evaluate the differences in features, and people value some things higher than others. I've been driving cheap econo cars my whole life, so that surround view safety thing just isn't very important to me versus range. But for some people that might be different.
Right. There are some people who value safety measures by far above absolutely everything else, which is the reason why Volvo continues to exist, despite being bad in looks, performance, etc.So what you're saying is there is no absolute definition of what is an upgrade or a downgrade. Anything could be considered an upgrade over anything, depending on one's priorities. So even a bicycle could be considered an upgrade to a P100D, for those who value open air the most and maybe live somewhere where there are no chargers.
So maybe service should have said "some people consider it an upgrade - has more safety features but lower performance", and present it as a customer choice, rather than saying "it's an upgrade", because it's also a downgrade in performance.Right. There are some people who value safety measures by far above absolutely everything else, which is the reason why Volvo continues to exist, despite being bad in looks, performance, etc.
So after some melting outlets and fires from the Gen 1 mobile connector not having a temperature sensor that could have stopped those, a lot of people might consider that a pretty significant improvement, regardless of what max current level it could do. So I was just calling out that it's not really accurate to say the Tesla sales person "lied". He wasn't knowingly being deceptive. That's a difference of what people value.
