Cottonwood
Roadster#433, Model S#S37
It's a bad idea to connect a Tesla via a NEMA 14-50 adapter to a 30A circuit. If closely monitored, it's likely going to be okay, but you shouldn't make it a regular habit if possible. If you do, I recommend that you build a 14-30 to 10-30 adapter cable and use it with Tesla's 10-30 adapter to prevent overcurrent (or see if you can find a Tesla 14-30 adapter still hanging around).
With the number of Model S's on the road today, and a corresponding number of UMC's, I don't understand why Tesla does not make more adapters. This would make connections easier and safer for Tesla owners.
Here is my list in priority order; I could probably live without the last few, but up to 10-50 would be useful in a reasonable number of locations. The current ratings are connector and breaker ratings. All charging should be at 80% of these current ratings.
- 14-50 — Most common RV and kitchen range outlet. 240V/50A
- 5-15 — The standard 3-prong, 120-Volt, trickle-charge outlet. 120V/15A
- 5-20 — 20 Amp, 120 Volt 3-prong outlet. 120V/20A
- 10-30 — Old dryer outlet. 240V/30A
- 14-30 — New dryer outlet. 240V/30A
- TT-30 — 120 Volt RV outlet. 120V/30A
- 6-50 — Welder outlet. 240V/50A
- 6-20 — Air Conditioner outlet. 240V/20A
- 10-50 — Old range outlet. 240V/50A
- 6-30 — 240V/30A
- 6-15 — 240V/15A
- 14-20 — 240V/20A
With just a few more adapters, Tesla could make connecting the UMC to a variety of sources much simpler and safer.
