Okay...another question. Only because I'm thinking I really might do this. What would you say is the most expeditious sequence for getting an EVSE installed? Is it best to contact the utility first (in my case, SoCal Edison) and get the process moving, or to contact an electrician first? I'd have to get a a NEMA 14-50 installed first, and from what I've read here and elsewhere, probably a second sub-meter for the EV circuit. From start to finish, typically how much time are we talking about?
On a related note, in the interim when you had an EV but no EVSE, how easy was it to live just charging with a 110/120v charger and/or public charger? Based on the PlugShare map, it seems like there are plenty of Level 2 and even CHAdeMo chargers within a reasonable distance of my house.
How far do you typically drive?
Do you have a 120V outlet in your garage/carport?
Both the Volt and the Leaf should come with a 120V EVSE, which is enough to fully charge a Volt overnight, or mostly charge a Leaf - so if you're not driving more than 30-40 miles in the typical day, you should be able to charge that way indefinitely.
No idea about the timing question - I had a 240V outlet installed when they were installing my solar system, and plug an EVSE into that. I also don't have any special EV charging rates - but I don't pay crazy California energy prices, either.
Walter
