I said 0-35. And I have never NOT been first/fastest off the line. I floor it at every intersection. No one else is trying.
- - - Updated - - -
Drive a dual clutch car much? Look at the video I posted. Stare at the speedo. Tell me when the power is interrupted.
Of course you're right, to a point. It also takes a bit for the turbos to spool. My question is how all these factors shake out in the real world. Plus, I generally know at least a second or two beire I am going to mash the throttle and can blip down to the optimal gear in a couple of clicks...
A DCT is fast, but there is still a delay. It's mostly a problem at lower speeds under high acceleration because you have multiple, rapid upshifts.
The real issue with DCT's is that Tesla has no expertise in building them, or transmissions in general. The motor on the Model S is rated to go 200mph, but it can't go that fast because it doesn't have a transmission to get it there. With an advanced transmission the Model S could effectively compete at every speed, and have an advantage because the powerband on its electric motor is much fatter than an ICE like M5.
As it stands MSP is sacrificing acceleration in the 0-60 range for additional performance in the 60-100 range. With an advanced transmission MSP might well be able to get to 160mph quicker than M5, because the narrow power band of an ICE forces M5 to use a lot of space in its transmission for gears optimized for low speeds. MSP could keep the single short gear it has and pack its transmission with long gears that offer a mix of efficiency and high end acceleration.
