Mycroft
Life happens
Every time I see that magic drive train, my heart beats faster. A true work of art, both aesthetically and technologically!
Thanks for the pic.
Yes, you could remove the rotor that way, but what about the stator/case?
From the pic you posted, it looks like both motor bearings are lubricated by gear oil from the differential.
Does anyone ever have to service the motor?!? To be more specific, I would expect the motor to need servicing about as often as the differential (a very long interval), so I don't see this as an issue.While looking at the pics of the drivetrain from the skateboard mule, I have noticed something interesting. The Model S motor case seems to be integrated(welded) onto the differential case. That can't be a very service friendly proposition, as you would almost certainly need to disassemble the differential to do any work on the motor. I wonder if the production motor would be the same setup?
That is an interesting question, because yes, I believe sealed motor bearings have longer longevity. I wonder if this is related to cooling.Another thing I noticed from the very first pic in this thread of the Model S motor is, Tesla seems to be using a front motor bearing that is oil lubricated by the differential oil. Not that that is a very bad thing, but don't sealed motor bearings have much longer longevity?
I wonder if these are cost cutting measures?
Discuss.
It usually isn't an issue, but sharing fluid with the differential has two downsides.Does anyone ever have to service the motor?!? To be more specific, I would expect the motor to need servicing about as often as the differential (a very long interval), so I don't see this as an issue.
Could you describe what specifically gives you that impression?... it looks like both motor bearings are lubricated by gear oil from the differential.
If you look at the pic of the motor input shaft, the front bearing is of the oil lubricated variety(you can visually see the ball bearings).Could you describe what specifically gives you that impression?
In the skateboard model s pic,there is a gear-lube line going from the diff to the rear motor bearing.
Now don't get me wrong, high quality lubed bearings can and do last a couple hundred thousand miles, but there are many reasons why sealed bearings are better for an electric motor application.
The only reason I think Tesla went with lubricated bearings is cost. I would bet that a high rpm, high quality sealed bearing is substantially more than a lubed one.
The model s motor is already water cooled.
I assume you mean the thin metal tube with the Swagelok like fittings. I was told that's a coolant line.In the skateboard model s pic,there is a gear-lube line going from the diff to the rear motor bearing.
I was told 1, no mention of 2.Maybe its one of these two things:
1) They have the coolant right there anyway, so why not cool the diff.
2) A bunch of metal components bolted together, cooling one and not the other might cause stresses from the different temperatures and expansion rates.
That's a good observation, though it might just be for display. I assume you mean the image above. When I asked JB about rotor cooling back in 2009 he did mention the bearings as a possible path to get heat out.If you look at the pic of the motor input shaft, the front bearing is of the oil lubricated variety(you can visually see the ball bearings).
