The Leaf can do it, and the Model 3 is roughly Leaf-sized with much better aerodynamics. It shouldn't be a problem with the base 2wd sedan with LRR tires.Tesla is going to have to approach 4 miles range per kWh battery on the combined test. I think they will do it, but it will be quite the feat.
215 miles of 'real world range' with under 60 kWh battery will be very difficult.
A 55 kWh battery with a 50 kWh useable capacity is likely to have a useful range of no more than 180 miles.
I think that was true in the Roadster days but now the EPA is used. I have wondered though if Tesla is only quoting the anticipated highway component. It would make sense to me since that is where range is important.You have to remember that Tesla quotes range under the most favorable conditions.
As for battery longevity: the suggestion to not charge to 100% to extend life has merit on a daily basis but should not be a problem for occasional use.
Oh, for sure, although if the Model3 manages a Cd of 0.21 we should get a nice speed bump compared to the Model S for the same aero friction, somewhere in the range of 7%. A smaller frontal area will improve things even more. If say, 10% less frontal area then combined there will be an 11% speed difference. 60 mph in a Model 'S' vs 66ish mph in a Model 3 for equivalent aero forces.It has been a while since I used the configurator at the nearby Tesla retail location but when I last did they had a range slider where you could simulate highway speed vs anticipated range. Increasing the speed past 60mph or so had a pretty noticeable affect on the range.
You have to remember that Tesla quotes range under the most favorable conditions. Such as 55mph on the highway.
I am a bit concerned with a <60kwh pack. In winter, heating loads really do eat up a lot of energy. Reducing the drag coefficient does nothing to help this. This will not be a practical winter car, unless Tesla has come up with some kind of magic heating system that doesn't use much energy. Perhaps they will finally go with a heat pump for heating.
Still this news is bad to my ears. A lot of people will be buying or counting on buying the base model battery. If that doesn't work in the northern half of the country then we are going to see poor resale values of the 3 as people realize this car won't work for them. And perhaps a lot of angry owners who didn't realize what they were getting into. As a Model S 60 owner, it's a battery size that's just too small and I recommend it to no one unless they really know what they are getting into. In the summer it's "OK". But with the current supercharger spacing strategy, a 60 is a really poor performer in the winter. Most of the time I need to do a nearly full charge to get to the next charger. That's an hour or longer process. That will really kill a lot of electric car enthusiasm. The great thing about the 70D is that it gets much closer to the original 85 with just a bit more battery and improved efficiency over the 60. I understand that the Model 3 will be better efficiency than the S, which is why I was really hoping for a 60kwh battery. Then it would behave much like a Model S 70.
That way my car will be a 383 with 409 (it may be possible my muscle car roots are showing).
This is still a very practical car for the majority of those commuting in the winter. The average commute is about 40 miles round trip and this car will have range to spare even if driven in a sub-zero temperature blizzard.
Will this be a great car for frozen winter road trips? Probably not, but most of us have alternate transportation burning evil fossils for those kinds of situations.
One thing that will slightly assist with winter range is programming the car to heat up the cabin and warm up the seats before you ever disconnect from your home charger. Once you are on the road you can back off on the climate control substantially and basically "coast" on built up cabin heat for at least 20 minutes before the car really starts to feel chilly.
This is my concern, that people will look at it this way. I think that is exactly the opposite of how we should be viewing this. The EPA range is almost irrelevant in that it doesn't take into account winter heating.Please just forget the kWh rating of the battery, and look just at the range figure. Model 3 55 with "at least 215 EPA miles" will give you more range then a Model S 60 with "208 EPA miles".
So if it takes 5kwh of energy for either car, brand X car will have 10kwh-5kwh=5kwh of energy to actually go somewhere. That would be a 50% range hit. For car brand Y, they have 100kwh-5kwh=95kwh of energy to actually go somewhere. That would only be 5% hit in range.
Very good point, and it will be true for any bump in the 'fixed' costs of summer driving. More road resistance from water and snow, for example.This is my concern, that people will look at it this way. I think that is exactly the opposite of how we should be viewing this. The EPA range is almost irrelevant in that it doesn't take into account winter heating.
Perhaps I am not explaining my concern very well. So let me give this exaggerated example:
Two thoughts:So a Bolt with a 60kwh battery is going to perform much better in the winter than a Model 3 with only a 50kwh battery.
The difference in heating efficiency needs to be considered. The Bolt EV will likely only have a resistive heater, while the Model 3 may have a more efficient system similar to the S.
I was under the impression that the Model S had both a resistive heater and a heat transfer loop that harvests heat from the motor and electronics. If it just has a resistive heater, then my second point is invalid.What more efficient heating system does the Model S have? I thought it had two resistive heaters, one for the cabin and another for the battery. (Excess battery/drive train heat is not piped in to the cabin.)
..assuming the Model 3 uses the same heating system as the S and X, of course. But if they go to a heat pump with resistive backup, there could be a much more efficient heating system at the cost of more parts and weight. How about this for speculation - subzero package for Model 3 will include a heat pump, for colder climes. For warmer areas, it'll remain resistance heat only.Edit: ...and a quick search confirms my error. Model S cabin heat is resistance only. Model 3 and Bolt EV will likely have similar heating efficiency.
