Let's See Your Charging Setup
Model y and Model 3....$150.00. Installed
Model y and Model 3....$150.00. InstalledView attachment 629500
Looks good. You should support the Mobile Connector electronics unit so it does not hang from the power plug. Tesla sells a Charging Cord Organizer kit that includes a holder for the Mobile Connector.
Also, see Etsy for Tesla Wall Bracket/Mount for Mobile Charger Gen 2: Tesla Wall Bracket/Mount for Mobile Charger Gen 2 White | Etsy
Similar, more expensive is the Bastens Mobile Charger wall holder adapter for the Gen2 Mobile Connector available on Amazon: https://www.amazon.com/Bastens-charger-relieve-addition-connector/dp/B079RL6XL4/
You can also improvise a holder; anything that removes the weight of the Mobile Connector from the power plug/receptacle.
Reactions: Johnny Vector
Looks good. As noted in my Post #62 you should support the Mobile Connector electronics unit so it does not hang from the power plug. Tesla sells a Charging Cord Organizer kit that includes a holder for the Mobile Connector.
Model 3, but posting anyway
ChargePoint, because I get free weekend charging (just the supply side of .12/kWh, when solar panels finally get going, will then getting paid to charge).
The spring setup is a ‘button’ to release the charger, the white tape keeps the adapter attached (not necessary, but helps if overly aggressive).
Reactions: angus[Y]oung
Wish I had known about that Etsy mount when I did my garage. I MacGyvered my mobile connector electronics in it to my ceiling, but this would’ve been a much more elegant solution.
