TonyWilliams
Yes, that's what Flasher described above. It has to be the correct hot you use or don't use though. The UMC/car is picky about which hot 120V comes in on.
Yes, it is. You need the correct polarity.
For example, I wired a 15-40 to 15-40 adapter to use 120V instead of 240V, and the car displays 20A/40A and refuses to go up from there.
It seems that cars built fairly recently are capable of 40 amp charging on 120 volts. To test this, I temporarily wired my 6-50 outlet so one formerly hot side went to neutral instead of to the 50A breaker. I have the single charger, built March 2014, 85KWH. Don't try this unless you know what you are doing.
Awesome news that we will never see on the Toyota Rav4 EV.
20 amps is all we get on 120 volts.
I wonder about that 90 kw limit. I supposedly have an "A" battery too, but this is what I got recently charging at a new 120 kW Supercharger recently - the numbers multiply to 100 kW...
So not only have I not lost my mind (yet), I have a newer battery. Yea! Good start to the day.
I'm very jealous
Back, a few weeks ago i was asking members how to pull the most amps of 120v lines
I ended up using TT-30 RV plug, but it's limited to 20A
I'd love to have 40 instead
No. I have a B pack but a 20A limit.
