@wcorey best thing would be to put a label on your outlet as "30A max", so anyone coming after you is aware of the situation.When I decided to get the Tesla and sell the Prius, I was hoping to upgrade the subpanel to 100a rather than 50a, and upgrade that breaker to 60a rather than 30. Then I could put in a NEMA 14-50 and charge at the full 48a.
I believe I asked on here months ago what the supply to the subpanel was based on the wire used. The answer I got back was it looked like blah-blah-blah and could take well over 100a at 240v. I'll attach a picture of the plug from the L2 Levitron charger. It required a mated socket. Based on the orange covering for the 2' piece from the outlet to the breaker I deduced the entire circuit was now limited to 30a. right?
I would have preferred he use a 50a breaker and wire that to the NEMA 6-50 plug and then I could plug in a 30a load... That's the second screw up that electrician made. That and wiring my tower to the service ground.
As far as the L2 charger goes...it was UL approved.
It might be possible to fish #6 wire through your short wall run, rather than break the drywall. But, if your subpanel is only 60A, then it's probably a moot point.
