I just bought Model 3 (standard range/RWD). Also I bought mobile connector. I am planning to install 240V outlet in garage for the mobile charger. I am in condo with max rated Amp is 125 Amp. I have two empty slots available in circuit breaker panel. Should I instruct electrician to install 30 or 40 amp circuit breaker? If he install only 30 amp circuit breaker, my assumption is mobile charger will not draw more than 30 amp, though the mobile connector can draw 32 amp. If only 30 amp circuit breaker installed, how much miles I will charge per hour?
While your panel is rated 125 amps, it might be fed with a circuit that is rated less than 125 amps. As an example, I have a sub panel rated for 200 amps that is mainly used for lighting that is fed with a 60 amp circuit. So you need to know what your capacity is and the only way to do that is to find where the service equipment (main breaker) is located and examine it.
While you can talk about it all day, the only way to really know how much additional load you can install for an EVSE is to do a load study. You can easily do that yourself using Mike Holt's Electrical Tool Box:
While almost any 240 volt circuit will be adequate most of the time, even a 20 amp circuit, I recommend that you install whatever is possible as most of the cost of installing your circuit will be labor, and the labor to install a 50 or 60 amp circuit will be almost the same as the installation of a 20 amp circuit, especially if the length is only 20 or 30 feet.
Here is why I say, even though a 240 volt 20 amp circuit is almost always adequate, but recommend you install whatever is possible (based on your load study):
Normally, even with a 20 amp circuit you will be fully charged in the morning if you have all evening/night to charge. But, on some occasions you may need to charger quicker than that, for example 1) you suddenly need to go on a last minute trip and want to top off the car to 95+%. If you set the car to charge while you are getting ready for your trip you will gain more miles with the larger capacity circuit, 2) you might come home from a long trip one afternoon at 8% SOC, and want to go out later that day and need to quickly add 40 or 50 miles of range, or 3) if I am going on a trip, I will set the car to charge to 100% when I wake up in the morning and am getting ready (it will have been charged to 80% with its normal overnight charging). Having the larger capacity circuit will top off the car so it will be at, or close to 100% right before I leave. You will gain the range you might need quicker with a higher capacity circuit.
That said, I would not hold off on buying an EV if I could only install a low capacity circuit. The benefits are just too good to pass by the opportunity of owning an EV. And I would not spend a lot more money installing a higher capacity circuit if it required upgrading my electrical service or panel. I would only install the higher capacity circuit if the cost increase is just for the marginal cost of the materials, and a slight increase in labor as installing larger wire is a bit more difficult. But the cost difference between #10 wire for a 30 amp circuit and #8 wire for a 40 amp circuit should be slight.
Another thing, I do not understand your quote where it says "15-30 amp circuit breaker". That makes no sense. Is it a 15 amp breaker or a 30 amp breaker?
Last, I strongly recommend you install a Tesla Wall Connector. This will save a considerable amount since it does not need a GFCI breaker, and you can keep the Tesla Mobile Connector in your car. You may never need it, but if you do need it (and I have) you will be extremely glad you have it.
Hope this helps. Let us know what you end up doing.
