Plenty of people have blurred lines between personal and business uses of their vehicles where the ability to charge faster than 11.5kw on their own property with no downtime would be beneficial. Construction or other trades would be an easy example off the top of my head. Contractors can put hundreds of miles a day on their vehicles going between job sites and home base, towing heavy loads, etc. Time is money, sitting idle at a supercharger parking lot is not always a viable option. They may be edge cases, but like I said, it doesn't take a particularly active imagination to come up with them nor are they extremely far-fetched. Farming would be another super easy example.
There's also the obvious observation that not everyone lives in Sunnyvale with bountiful fast chargers at their beck and call.
Available solutions like this that reduce barriers to EV adoption outside the cozy temperate enclave of the Bay Area that most Tesla owners like to pretend all EV owners live in can only be a good thing.
No Model X or S produced in the last 5+ years can...
Yes, I outlined commercial uses as one of the few possible reasons for it in the earlier post. The question is what might call to have one in a private home. You're talking about having one in a construction yard, which happens to have a home at it. Even then, it's pretty hard to use up a full car's range regularly, unless you have bought small-battery vehicles, or heavy work trucks. Tesla only makes one truck and its range is long.
I live in a place with fast chargers around, and I have used my close charger once, for 10 minutes, in 6 years. Even when all I had was Level 1 at home. I used another charger 15 miles away early on as an experiment. So no beck and call.
The point about cold climates could be a valid one, though of course they affect fast charging the most, though if you are planning for that you're keeping the battery warm and not getting too many of the bad problems.
But my challenge remains. I would like to see some concrete examples, since it's apparently easy to think of them, for DC Fast in a residence. As I noted above if you are driving Uber in a suburban place, and putting in 2 shifts, it could happen. I would not rate that as a frequent use example. It's also challenging, because for this to make sense, you need to drive for 250+ miles (if you drive this much you should buy a long range car) and then you need to be at home for an hour, and then go out and drive for another 100 miles or more. Regularly. If you just do it a couple times a month, just use fast chargers on your route. You may not have any fast chargers near your home, but if you are driving 250 miles, it's pretty likely there are some far away that you will go by. But there might be exceptions, so would be interesting to see one outlined.
But if you're not driving long drives every day for a living? Just living life, commuting, errands, etc.? What's the use case to need 50kW? Or even 25kW? The latter is getting cheaper, but 50kW is not going to be so cheap for a residence since 400a+ service is rare there.
Now I have written for a while that it would be good to see 50kW public stations show up at places like RV parks and rural areas. But that's not for residential use. Even the folks at the residence in an RV park should largely never use it.
