Just want to say my thanks for this good article. I like to use destination charging at Airbnb houses. Convenient for nightly charging on multi-day vacations, a little better for the car, and cuts down on the length of the drive. I can arrive at a destination with only 7%, with no (few?) worries. I generally check ahead of time with the Airbnb host, getting permission, finding out out what they have. I made a 46 ft SOW extension cord; I found that it can be a LONG way from stove/dryer outlet out to where car is. My ext cord happens to be 1/2 10ga and 1/2 12ga, so I see 3 or 4v drop, at 32a. Not much drop at 24a. Weird cord, but it's lighter than one made all with all 10ga. I probably should restrict myself to 24a with this cord even with 50a outlet, but at least I can feel the cord to see how warm it's getting. I used a dryer plug on it, but removed the neutral blade so it works with 14-30 and 14-50 (and 14-60, if I ever found one of those). The article makes all this nice and clear. I bought quite a few different plugs for hotels, camping etc., but didn't bother to make the adapters. If/when I need one, I will change the plug on my ext. cord at my destination; should be less than 15 min job, and may never even need to do it. Doesn't weight that much to carry a few plugs. Embarrassing story: I plugged into a 14-50 dryer outlet at one destination and pulled 32a, assuming incorrectly that 14-50 outlet meant thick service wire. Should have set car for 24a. Things got hot and the UMC failed out as it should have; pretty sure it sensed the heat coming down the short conductor to the 14-50. (This time I was not using my long ext cord.) Even after setting to 24a, it still had problems b/c the 14-50 outlet had rust/bad connection inside. Turned off breaker, took it apart and improved things a little; finally worked OK. So it can be a tricky, risky business. Be VERY careful with these things. I could have burned the place down. Current situation is way not optimal. Hopefully in a few years, most destinations will provide an inspected, correctly wired 14-50 outlet that safely supports 40a continuous.
