Happens in Seattle downtown.Automatic, or manual? Can't remember rolling back in any of my automatic vehicles.
You simply learn to be quick whether you're in an automatic or manual. In an automatic you'd have to be on one hell of a hill to defeat the creep. In a manual, you learn to feather the clutch as you switch over so there's no "lurch" forward. If you have a hand brake, you can use that too.So what's your technique for a driving an automatic car in a steep road with stop and go traffic? As soon as you let go of the brakes your car will reverse and hit the car behind you. If you try to quickly move your foot to the "gas" pedal, you will more than likely over throttle and hit the car in front of you.
My wife grew up in that area and says that while it's not unheard of (foot on each pedal) it'd be very, very rare.Try driving the hills of San Fran -- they're steep enough to overpower any ICE's creep.
I am occasionally asked about using the left foot for braking instead of the right foot. The usual justification given for this is that the brakes may be applied more quickly because the left foot is ready while the right foot is busy with the accelerator pedal. While there are different schools of thought on whether this is appropriate for highway driving it may not be a good idea for the average driver.
An important job for your left foot and the leg attached to it is to press against the raised portion on the left side of the driver's foot well. This action forces the driver into the seat and anchors the body leaving the arms free to steer with during lateral acceleration and heavy braking. Staying in complete control means not hanging on to the steering wheel in order to keep your body in position.
If you get lazy and ride the brake with your left foot enough to light the brake lights will confuse the driver behind you. Are you stopping or not? Confusion like this will lead to an increased chance of being hit from behind and contributes to excessive brake wear and poor fuel economy.
In the event of a collision, the resulting pressure on both the brake and the accelerator will reduce the effectiveness of the brakes at a time when they are needed.
Finally, check with your driving examiner. Left foot braking during a road test may not be acceptable in all circumstances.
Depends on what area in SF. If you are near the Russian Hill and Nob Hill area, then you regularly come up on hills that will roll any car backwards. If you are quick enough then you will still have a little bit of roll (it's not non-existent). Two feet allows you to not have any rollback and gives you better control.My wife grew up in that area and says that while it's not unheard of (foot on each pedal) it'd be very, very rare.
I'll lay money that every driver's class that exists will tell you to only use your right foot for brake and gas, never use both.
Although I've never felt the need for a hill hold function (and now we live in Florida! FL=flat) I was surprised to find that a Nissan Sentra I rented in Vancouver had this function. Worked great not needing to use my feet at all to hold the car stationery uphill in the mountains of B.C. Odd though that downhill the car rolled forwards?
I agree every driving instructor will tell you to use one foot in general, but my instructor did give me a tip that you may use two if dealing with steep hills in SF.
Yes - I always dread having to stop at the traffic signal going up on a steep hill (and many of them in most roads) i.e. I used to until I started using the hill hold in Leaf.Happens in Seattle downtown.
How does the Hill Hold feature work in the Leaf?
I've got a Leaf and this is the first I've heard of this feature in this car.
My Prius has the feature though and it works fine.
Hill start assistance
This function assists the driver when starting on hills. It prevents the vehicle from rolling backwards, depending on the slope, by automatically applying the brakes when the driver lifts his/her foot off the brake pedal to depress the ac- celerator pedal.
System operation
It only operates when the gear lever is in a position other than neutral (other than N or P) and the vehicle is completely stationary (brake pedal depressed).
The system holds the vehicle for ap- proximately 2 seconds. The brakes are then gradually released (the vehicle will move according to the slope).
The hill start assistance system cannot completely prevent the vehicle from rolling backwards in all sit-
uations (extremely steep gradients, etc.).
In all cases, the driver may depress the brake pedal to prevent the vehi- cle from rolling backwards.
The hill start assistance function should not be used for prolonged stops: use the brake pedal.
This function is not designed to im- mobilise the vehicle permanently.
If necessary, use the brake pedal to stop the vehicle.
The driver must remain particularly vigilant when driving on slippery or low-grip surfaces and/or on hills.
Risk of serious injury.
Not yet. But there is some word of it coming...John Voelker at Green Car Reports has had confirmation from Tesla that there is no Hill Hold.
pilotSteve said:Then to top it off got to chat with George B for about 30 minutes on lots of topics. My wife and I are really impressed with George. He is genuine and spoke very clearly about several issues. I asked him about the hill hold mode (not present yet). He described how the engineers are currently prototyping this function with various combinations of motor hold and park brake. They are not yet satisfied with the smoothness upon release so are not going to release that until its perfected. This is EXACTLY the sort of answer I was looking for from a senior executive.
I don't see any evidence of automatic hill start / hill hold on the LEAF. Searched the web and my pdf copy of my 2011 user's manual. They do describe manually using the parking brake to hill start and they do warn against using the motor to hold your position on the hill (as opposed to the brakes). I have not yet found myself stopped on a severe uphill to see if the parking brake is necessary to do a smooth hill start.
I don't know of an automatic hill hold/start that is enabled automatically. The parking brake can be used for hill holding by simply activating when stopped. When it is time to go just press the accelerator and the parking brake will release automatically (provided you have your seat belt on). In a fashion this automatic I suppose since you don't have coordinate releasing the brake.
arnold
