But what about when the doors are locked on the Model X?
Here is the answer with additional data to help answer additional questions. The self closing charge port operates differently than my Model S non-closing port.
When Model X is locked, the port will NOT open by pressing the left side of the reflector.
While Model X is locked OR unlocked, the port will NOT open by pressing the button on a Tesla charge handle. The port will open when the key fob hatch button is held down (or the left side of the reflector is pressed while unlocked). It will NOT open when my
Model S key fob hatch button is held down.
To remove the Tesla charge handle when the Model X is
unlocked, a press of the charge handle button is needed OR you can hold the key fob hatch button to release the handle. A single press and release of the button to the left of the charge port releases the handle when unlocked and
not charging. Even if the charge session is over, the Tesla charge handle cannot be removed while the Model S or X is
locked. A press of the Tesla charge handle button will restart a charge session, even if the vehicle is locked.
After charging with a J1772 adapter, the port cannot be unlocked to remove the adapter unless the Model X is unlocked. Since the Tesla charge handle button won't unlock the adapter, Model X drivers do not need to be concerned if they are charging at a J1772 next to a Supercharger.
Unfortunately, my 2012 Model S does allow the removal of the J1772 adapter while the vehicle is locked if a Tesla charge handle button is pressed while the vehicle is locked and the J1772 handle is removed. Keep that in mind if J1772 charging next to a Supercharger.
