Hey Linkster thanks for crawling around to get those views of the right hand lower attachment points.
i can see an offset washer in a slot that would allow an eccentric adjustment in the position of the arms, and i would guess that the washer is welded to the nut.
So it looks like the aft lower control arm has the lateral adjustment for camber, whereas an adjustment of the forward lower arm will affect many aspects of the alignment: caster, wheelbase, camber and toe. Of course final toe-in adjustment is in the steering tie-rods.
I wonder about the function of the aluminum plate welded to the aft mounting flange? That flange is bolted to the chassis and you can see how one of the flange holes is slotted with a wide opening to slide around the bolt--probably a feature to allow quick assembly on the build line, but it makes for a weaker mounting joint with the wide slot. You can even see that there is very little of the bolt head in contact with the mounting flange.
