Benjamin Brooks
Why do you say that?
He probably confused range mode with range charge.
One of these days someone is going to have a serious accident because of one of these poorly QAed releases. Tesla really needs to get its act together on this. Software QA is not as easy as it sometimes seems. But in this case it's all the more vital that it be done carefully. If I were Elon I would Fire my firmware QA manager and double the budget for his replacement . (Of course I don't know the details of their organization so this isn't a serious suggestion. It's just meant to indicate the serious ess of the problem)
I speculate people are thinking that there is little battery pack heating while the car is in Range Mode. I think people are also speculating that with less pack heating that this may somehow be detrimental to battery life/longevity.
Build 167 seems to be a huge improvement for me. Much better efficiency, and the TACC (traffic aware cruise control) feature seems to be much smoother / less jerky.
I don't use range mode, as I haven't gone on any long trips recently, and I think it's probably not good for long term wear on the battery to use range mode unnecessarily.
That's good news, toto. How about you, Andyw2100: weren't you one of the D owners not seeing any benefit under .139/.140?
The question is still open as to why some cars saw significant efficiency improvements (mine is one of them) under .139/.140, and others did not.
EV Trip Planner | ||||||||||||||||
Estimates: | ||||||||||||||||
Date | Distance | RM | Total Energy | Avg Energy | Hwy Speed | Cabin Temp | Outdoor Temp | Wind | Elev Change | Conditions | Distance | RM | Total Energy | Avg Energy | Spd Factor | |
2/23/15 | 54 | 72 | 21.3 | 394 | 60-65 | 68 | 2 | 1CW | (754) | Clear, little slush | 52.6 | 67 | 20 | 380 | 0.96 | |
2/23/15 | 53.5 | 82 | 23.9 | 447 | 60-65 | 68 | 2 | 1CW | 754 | Clear | 52.2 | 76 | 22.7 | 435 | 0.96 |
Anybody have software post .140? I have .140 and the car is updating right now.
I assume, mesalum is not getting .167, but a newer bugfix.
I'm going to guess that without range mode this update will have no impact. I'm still of the opinion that issues are being caused due to torque sleep changes that are potentially too aggressive or that need further tweaking. To be fair to the QA people the precise circumstances to recreate this seem to be many and varied variables, I.e. The only common factor so far is range mode, presumably because the changes only operate in that mode.The one round trip my wife took yesterday we saw absolutely no improvement.
She drove to work with range mode on, but then home with range mode off, because by then I had read here that the issues with .167 were limited to range mode being on, and we were much more interested in getting her home without issue than in testing efficiency.
I noticed that there was some ice build up in the wheel wells that I removed, but I really don't think that could have been what was causing our efficiency issues.
I'm taking the car this afternoon, and will see how it goes, but will also be driving with range mode off, because of the issues with .167 and range mode.
Below are the numbers and comparisons to EV Trip Planner for yesterday's trips.
EV Trip Planner
Estimates:
Date Distance RM Total Energy Avg Energy Hwy Speed Cabin Temp Outdoor Temp Wind Elev Change Conditions
Distance RM Total Energy Avg Energy Spd Factor 2/23/15 54 72 21.3 394 60-65 68 2 1CW (754) Clear, little slush
52.6 67 20 380 0.96 2/23/15 53.5 82 23.9 447 60-65 68 2 1CW 754 Clear
52.2 76 22.7 435 0.96
If the problem is with torque sleep in .167 then it's not relevant to @mesalum since he doesn't have a Dual Motor car according to his signature. At least I haven't seen anyone reporting problems with RWD cars on .167.
Maybe that is why they have made most of the improvement only accessible through range mode - it can be turned off if stuff goes wrong.
There isn't a concrete answer on what range mode does exactly, but there has been a lot of speculation that it allows the temperatures to float both higher and lower before kicking in active cooling. High temperatures absolutely degrade the battery, but might be a worthwhile trade-off in order to make a trip that would otherwise be impossible (say: the drive from Los Angeles to Las Vegas) ... Cold temperatures are fine at a low drain rate, but doing 0-60 runs with a cold battery is not great either.Why do you say that?
