Dragonfly
I've had a Neuton CE6 for three years now, the CE6 has the larger 19" blade. It's awesome. It's about the same power as a 4hp gas mower. Most gas mowers run around 6hp today, so it's a little less powerful than the average mower. That said, it's done a great job cutting my 5000 sq ft of turf. It also does a pretty good job sucking up leaves. I always bag, and never mulch. The weak point is the blade. I think they're made out of butter. They bend, nick, and dull at the drop of hat. No gas, plugs, oil changes, carb tuning, etc. The battery is always ready to mow. I have two batteries, just in case, but I've rarely needed to use both in one mowing. With the battery in the mower weighs about 50lbs, with the battery out, it weighs about 30lbs. (The 36v lead-acid battery is heavy.) You can hang the mower on the wall with the battery out. Only one moving part - the electric motor.
http://www.neutonpower.com
Edit: Rumors of a lithium ion battery upgrade persist, but I've seen no evidence.
