Indeed a wealth of information. Thanks all. I will get a 5-20 adaptor and 10 gauge extension. I also thought of getting a 14-50 extension. Do these exist?
Why not just use one extension? Get the 14-50 extension and use that with the 5-20 or 5-10 adapters
http://www.corddepot.com/shop/50a-straight-blade-cords/50-amp-rv-cord-ergo-grip/
http://www.corddepot.com/shop/power-adapter/5-15p-to-14-50r-ev-adapter/?add-to-cart=6173
http://www.corddepot.com/shop/power-adapter/l6-30p-to-14-50r-ev-adapter/
etc
Yes, the Amazon one is way too big and bulky. I made my own with these parts:
6 3 SOOW So Cord 25 ft HD USA Portable Outdoor Indoor 600 V Flexible Wire Cable | eBay
Camco Power Grip 55353 50amp Receptacle Fast Shipping | eBay
Camco 55255 50 Amp PowerGrip Replacement Plug New | eBay
More info here:
How to build a lightweight 50A extension cord
"Standard garden orange extension cords" aren't made to take 12A continuously for hours. i hope you didn't awaken to a big problem. You really should get a 12 or 10 gauge cord for next time.
Congratulations on your full charge, but I don't think you understand how serious using an improper cord can be. The awaken to a big problem I was referring to wasn't the lack of a full charge, it was an electrical fire. You may not be so lucky next time. Please check the cord gauge and if it's less than 12 gauge keep it in the garage for your weed eater and get a 12 or 10 gauge for your car.I woke up to a full charge. I have pictures posted on Plugshare.com.
- K
You're right, if the run is short enough, but I worry about the plugs at either end of a 14 gauge cord not being designed to carry that current continuously for the 10 hours or more, perhaps many more, that a Tesla is likely to be charging. Going to the next gauge gives some margin of safety.I just don't see a safety issue with a 14AWG at 12 amps. However, a 16AWG would need to be liquid cooled :biggrin: at 12 amps.
You know what? I can't fault anyone for safety around electricity. You're giving good advice and I support it. Thanks for saying something!
- K
I wouldn't be surprised at all if it's less than 12 gauge. Most extension cords sold for lawn and garden use are 16 gauge. Please do yourself a favor and check the gauge stamped on the cord.
Not unexpected. Most garden tools just don't pull heavy enough loads to require more than that. Most of the heavier extension cords are marketed to contractors who sometimes run several tools off one cord or run much heavier tools (like jack hammers or soil compactors).Whoops, I checked and was surprised. I have a 50 foot orange one, and then I have a 10 foot thicker heavier black one that I thought would be even bigger gauge. Nope, they are both 16 gauge. I think I’ll acquire a 12 gauge cord.
Also, the US spec for voltage is 120v/240v single phase (and for 3-phase LV; 208v or 240v depending on wye/delta). There is a tolerance, which varies from location to location, but it's usually around +/- 5%. There has been no "110v" or "220v" specs for the better part of a century, so when you say 110v outlet, you're really showing your roots. =)
Forget Voltage, My grandfather (RIP) used to call it "Juice".
