Is that a 20A 240V garbage disposal circuit? What are you putting down there?
Converting the garage to 240V outlets (NEMA 6-20 if the wiring supports it (12ga?) or 6-15 if it doesn't) seems like the best option. This would of course make the garage outlets mostly useless unless you buy the European version of everything you'd like to plug in there.
The garage lighting and door might be on the same circuit though so it might not work... You've got figure out what wires are going from the condo to the garage. If there are two circuits going there then there's hope. Switch the "com" breakers individually and see where they go.
