As pointed out above, the CAC number can be manipulated. Shallow charging the pack for a long time will bring it up. That's why Tesla takes multiple things into account when considering battery health when you take the car in.
Incorrect. A complete log file history provides the best information. Heck, a single log file provides better information and is easily obtained.
For me, that's because I consider it pointless.
Now it seems we have a comprehension problem. CAC is the single most accurate measure of a batteries health. Or it's the most accurate single measure. Would a full analysis of the complete history of the vehicle provide more information? Yes. Would it provide better information? Maybe, maybe not.Incorrect. A complete log file history provides the best information. Heck, a single log file provides better information and is easily obtained.
What I have repeatedly said is that the CAC number is simply not accurate.
Voltage only tells a small part of the story. This is why Range predictions vary so wildly between different manufacturers. If you have driven a Leaf, you will know what I mean.Well like I mentioned, Tesla has the brick's Vmin when the ESS is getting hammered, that alone is a strong data-point Tesla grabs and uses for the CAC data that's fed to the algo. That is not dependent on a shallow charge behavior. Its the same, the weak brick no-matter what SOC will dive like a rock compared to others.
That's my point. If taking only Voltage into account was most of the picture, then there wouldn't be such a wide variance in range estimates.But that's what Tesla got right and the others didn't, that's what's so proprietary about their algorithms, computations that give them the competitive edge. I *never* had a false range reading on my Roadster. Ever.
My CAC increased from 141 to 154. Why? Because the battery was replaced. But you won't see that in the logs.
I never said I would pay more for wiztecy's car, so stop basing the success of your argument on that falsehood.
I really don't know what point you are trying to make. If it's as easy as you say, maybe you need to forward that link to Nissan's engineers, obviously they must have missed it...Battery Voltage Information – Battery University
"The voltage behavior under a load and charge is governed by the current flow and the internal battery resistance. A low resistance produces low fluctuation under load or charge; a high resistance causes the voltage to swing excessively. Charging and discharging agitates the battery and full voltage stabilization takes up to 24 hours. Temperature also plays a role; a cold temperature lowers the voltage and heat raises it."
"Voltage" does help us understand and it directly represents what's happening in terms of resistance is of the battery, and that's very important as to what's going on and how its doing overall unless I am not interpreting the above information incorrectly. A battery that has degraded chemically will have higher resistance holding other variables like temp constant. And there are other tests that can be done, as I mentioned to get a clearer picture and overall health of the pack.
And where do you think the "logs" go??? Into the CAC algo.
Have you even realized Tesla keeps all the Temp data as well as the charge behavior in their logs?
When someone says its "pointless" I say that's a cop-out.
So after a range mode charge and low discharge, and even after a year where if my CAC is higher than 146, you'll still be a disbeliever.
Only because you're ignorant of the reasons, and apparently don't need to hear the reasons to attack them.
Ohh really? I easily could make the same statement. Its part of a discussion and educational argument. And how am I "attacking"?
But you don't want to validate your side. If you have nothing to lose I don't see why you don't line them up to see where the numbers end.
You're splitting hairs. My comment is obviously discussing the one best measure of battery health. You're claiming that some in-depth, detailed analysis of the vehicle logs (which may or may not actually be available) is more accurate? You cannot definitively prove that. Your personal analysis of the logs will never be the measuring stick. Now cool it on the personal attacks. That BS is out of line.You know, supersnoop, when your argument is based parsing individual words, you should watch out.
When your argument is based on reordering individual words differently, you're in trouble.
And when your argument is based on reordering individual words that weren't actually said, there's no hope.
witztecy said: The CAC is our and Tesla's best gauge for overall health of the ESS. There was no use of the word "single" in that statement. So, um, who's got the comprehension problem?
In my example, the CAC is more accurate than the logs. It's one argument. I never said the logs were useless, but, unless you're a Tesla engineer with a comprehensive background in battery management, the CAC is the better measure, and the logs may assist in explaining any anomalies.I'm screaming inside my head again. That's an argument against my saying using logs is better than just using CAC?
No, you didn't trick me. I can't even tell if you actually read my answer. My answer was, "it depends." But I set the hook for you anyway. And now, while you claim others are building a straw man, you're building one of your own. If you have to resort this tactic to make your point, then you have no point to make.Hey, I gave you fair warning in advance that it was a trick question. I'm sorry it succeeded in tricking you, but maybe it's taught others not to put too much faith into CAC values that differ by only about 5%.
From my experience, I can tell the pack also balances way below 82%. Then it also changes the CAC value. I see 5 to 20 CAC value changes each week!
