Blurry_Eyed
MS Sig #267, MX Sig # 761
What is the rectangular box that sits on top of the battery back towards the front of it? Anyone know what it contains?
Section 0039 in your link mentions fluid coolant.I don't think the ACP pack was liquid cooled...
BATTERY PACK THERMAL MANAGEMENT SYSTEM - Patent application
That's 2 battery modules stacked on top of each other (there may also be some coolant hoses under there). The other 14 modules are single layered (not stacked).What is the rectangular box that sits on top of the battery back towards the front of it? Anyone know what it contains?
@CapitalistOpressor - exciting work - thanks. Make things much more clear.
If you know mfg any core is always cheap to make, cost goes up dramatically with the add-on. Smart move because now he controls the cost of the system and can make improvements in house. I don't think he pays more then 50 cents for the core.
Also interesting big companies would buy components and stop there ( whining about cost to high ), Elon takes an everyday item and strips it to the core what can we do less expensive. (I am working in a big company taking things apart and use only the essential stuff and do the rest ourselves would never fly with management).
Very exciting insight !
Yes, the patent I linked was from Tesla's work to productize what was started in prototypes like the ACP cars.Section 0039 in your link mentions fluid coolant...
I misunderstood what you were saying then. You are right that ACP didn't use liquid cooling. Even the MINI-E had an air-cooled pack:( I was trying to say I don't think ACP used liquid cooling, but "see here" where Tesla patented liquid cooling as an improvement.)
The key is obviously just how much does that actually save. Just having to make Tesla special production runs could increase costs. Shipping to Fremont may actually be a significant cost depending on what % had to be air freighted. I therefore took a far more conservative approach to the pricing and I think the truth is between our two numbers.
CapO you're out of control. Thanks for the detailed analysis.
Cross posted because it relates to this thread -
There is no need for a separate production run. The only difference is the cap, which is manufactured separately, and then integrated into the cell. The cap of a conventional cell is a highly complex device, with several safety systems to prevent the cell from exploding during use. The cap of Tesla's cell is an aluminum disk that has a gasket ultrasonically welded to it.
A Tesla "production run" consists of the worker ultrasonically welding a Tesla cap to the battery at that stage of the production process. This amounts to reaching into a separate bin for the appropriate part.
Here is a video that demonstrates the manufacturing process. I'd suggest watching the whole video to understand how the films are made for the internal guts, but the processes relevant to the cap start around the 3:00 mark. After the necking process, you integrate the cap, but in the video, they are demoing the machines instead of production sequence. You'll see the cap integration maybe a minute later during the spot welder demonstration.
Again, at this point you just reach into a different parts bin. And the Tesla part is vastly cheaper.
Before viewing the video, please look at the relevant patent diagrams. Here is the conventional battery -
Cell cap assembly with recessed terminal and enlarged insulating gasket - diagram, schematic, and image 02
And here is Tesla's battery -
Cell cap assembly with recessed terminal and enlarged insulating gasket - diagram, schematic, and image 01
The cap is a very expensive part of the battery (possibly the single most expensive part), as it takes large numbers of tasks to complete. If you look at the whole video, you will see how the films for the internal guts are just an automated rolling process, and you add chemicals. These cores should be incredibly cheap.
It sounds like a separate production run to me. Why don't you think they're having Panasonic or somebody else build the batteries to their (Tesla's) specs including the cap? That would be much more efficient since Panasonic already has most of the equipment and can do it in the same line and production run. I don't think they have "workers reaching in bins" I suspect it's all automated, but don't know for sure. I also doubt if they're ultrasonically welding the gasket to the cap. It's more likely that they're welding the leads and tabs to the cap. The caps are aluminum and ultrasonic welding allows them to use a dissimilar metal for the leads. It's also useful because it doesn't make anything hot so it can be performed while the cap is in close contact with less temperature tolerant materials like the large gasket.
Well, they won't be having Panasonic build the battery because it's cheaper to do it themselves and it protects their IP.
I agree the core+cap would be automated. In case people didn't notice, the video CapO posted said it was for testing: small equipment to make small test battery runs at reasonable cost. I 'm sure battery manufacturers do a large number of test iterations and efficie t small-scale manufacturing would save a lot of money.
Elon has stated on more than one occasion that the cell chemistry is different to the standard 18650 cell. I would have thought that would mean a separate production run?
It oughta be automated. Whatever process you use though, you will just feed the appropriate caps from a parts bin.
It has nothing to do with protecting their IP. It's way cheaper to have Panasonic do it because they already have factories built to produce batteries. Tesla doesn't, and they are capital constrained. Their IP is already protected whether they contract to have Panasonic build the cells or do it themselves.
How can you be so sure? Having worked a lot in companies with IP, my experience is that you don't just rely on your patents. You rely on not letting others see how you do things, and to ensure that you learn more about the processes than anyone else. When people get practical experience with your IP, they get a much better understanding of both the IP and the subject matter, making it much easier for them to circumvent your patent, challenge it in court, or invent around it.
If you have important IP, you want to keep the related process inhouse as much as you can.
