bdy0627
In actuality, I would always sell the options regardless whether they are up or down. It's just a question of when and what i am doing with the proceeds. Dynamically adjusting your leverage depending upon the stock movement, leveraging up when the stock takes a dip, and down when it rises, can improve your risk/reward outlook. Assuming your fundamental outlook on Tesla doesn't change, it certainly makes sense to leverage up on a dip. Since we are not at a dip but are near an ATH, yet expecting explosive growth, it makes sense to be in LEAPs but not so aggressive or leveraged that you can't leverage up if we were to drop back into the $200s. This is why I believe it is not overly risky to be in DITM LEAPs now but I do think it is relatively risky to be in OTM LEAPs, certainly at 100%. The key to me is simply to be able to reasonably increase your leverage in LEAPs via strike price or expiration date should the stock go down.That's not true,! You are missing the fact that you can be forced to sell your options but you can hold your shares as long as you need to.
And by following that strategy you lose most of the potential benefits of options. I believe that a better strategy is to avoid LEAPS options until you have excellent reasons to be extremely confident that the SP will increase a lot a substantial amount of time before expiration. I believe that now (between now and mid 2019) is clearly one of those times.
I believe that being all in on LEAPS all of the time is too risky but when it isn't a risky time that strategy is too conservative. Very high risk with medium rewards.
Using the options calculator here is an example investing $100k right now:
Buy 11 J19 $300 (at $91.5 each) or
Buy 23 J19 $400 (at $44.2 each)
If the stock is at $430 on 2/1/18:
Your J19 $300s are now worth $159k (at $145.2 each)
Your J19 $400s are now worth $177k (at $78 each)
However, if instead the stock is at $280 on 2/1/18:
Your J19 $300s are now worth $39k (at $35.1 each)
Your J19 $400s are now worth $25k (at $10.9 each)
At this point, if you owned the J19 $300s, you could just hold on or you have an opportunity to sell them and use the money to buy 35 J19 $400s since you are even more confident the stock will be going up from there. Be greedy when others are fearful, right? Again this absolutely assumes no fundamental change in the company outlook.
Let's say you held on and the stock then rises to $430 by 5/8/18:
Your J19 $300s are now worth $153k (at $139.9 each)
Your J19 $400s are now worth $156k (at $69.0 each)
If instead you had sold the J19 $300s and bought J19 $400s while the stock was at $280 on 2/1/18, here is where you would be if the stock then rose to $430 by 5/8/18:
35 J19 $400s at ($69.0 each) = $241,500
If the stock continued to drop from $280 on 2/1/18, I would be looking to leverage up again when I felt it was at the bottom. It's impossible to perfectly nail the timing but you don't have to be perfect as long as it eventually goes up. You do have to be right on your assessment of the company. If it hasn't gone up before the end of 2018, then you would need to look at J20s at an aggressive strike price.
The bottom line is that the best risk/reward ratio comes after a dip rather than near an ATH. Best to be cautious with OTM calls near an ATH.
