Not sure if this is old news, but I noticed only today - when you have TACC active (no autosteer), and try to merge into a lane with slower traffic, as soon as you turn on the blinker TACC matches speed to the traffic in the desired nearby lane as if the car behind which you are mergin was in front of you in your lane. pretty neat.
Every car on the road has to adapt his driving to the vehicle in frontWhat happens to the car directly behind you in your lane? Are they forced to brake suddenly?
Not all that suddenly. There were no cars behind me in this case.What happens to the car directly behind you in your lane? Are they forced to brake suddenly?
What happens when you try to match speed to a slower lane to merge there with traffic behind you? Same here.
You must be living in some different Seattle than the one I need to visit sometimesI time the lane change such that I can safely decelerate in the new lane. This reduces the odds I will be rear ended. Decelerating in the old lane will surprise drivers behind you and is asking for trouble.
Load Limits:
Secure all cargo before moving Model S/X , and place heavy cargo in the lower trunk compartment.
Caution: Never load more than 175 lbs (80 kg) on the rear load floor (above the lower trunk compartment) or more than 130 lbs (60 kg) in the lower trunk compartment. Doing so can cause damage.
The hitch receiver is designed to support vertical loads of up to 120 lbs (54 kg) lbs (54 kg) carrying bicycles or other items on the Model X hitch, always check to ensure that the maximum weight is not exceeded. ...
When Model X is equipped with winter tires, the Maximum Towing Capacity is reduced.
Tesla assumes no responsibility for damage or injuries resulting from towing a trailer, for any errors or omissions in the instructions accompanying towing equipment, or for your failure to follow the proper instructions. Damage caused by towing a trailer is not covered by the warranty.
