Really? So do you get hot air basically instantaneously when turning on the heat in an S/X like you do with a space heater? That's awesome if true.
It could be instant, but it's more like several minutes to get to full power, because of software.
To me that completely defeats the purpose of having an EV... The moment I have to burn a fossil fuel, might as well go buy a BMW...
Jeff
I had thought that pretty much every EV resistive cabin heater was in a coolant loop for safety reasons (and/or maybe other reasons too, like smell, or noise, or packaging difficulties of having a high-powered direct-to-air heater in a car, etc.).
Mine seems to be pretty instantaneous, but it probably does try to balance the electrical load between the cabin heater and the battery loop, at least at startup if the battery is very cold.
There's no balancing. It's just slow. Looking at a log from Saturday, starting at ~20F outside only hit full power in the 4th minute of being on.
The system also scavenges heat from the motor and battery, if available, and that part requires the coolant loop to warm up.
Why in the world would it work like that? Is there some physical limitation to how quickly PTC heaters can safely heat up?
It maybe partly be to limit thermal stress on the element and rest of ductwork. It may also be the time constant of the software filter that adjusts heating power while driving (in which case they might want to add a condition for initial heat up to speed things along).
I would bet any amount of money it's the latter. Stuff that doesn't get used normally in Palo Alto works very poorly. You can guess the whole list without me telling you:
Wipers
heated wiper nozzles
battery heater
cabin heater
heated steering wheel
heated seats.
Shall I go on? No need to go into details of how they don't work quite right.
I wouldn't buy a GM car, ever. My only interaction with them will be at a rental agency.GM had heated wiper fluid system that burned up. Wife's GM heated seat overheated then failed. Same GM had a broken air door that caused 100% cold air all the time. Same GM rear wiper doesn't even touch the glass. Replaced at least 2 wheel bearings and the transmission on two of our GM cars. GM rear diff AWD solenoid failure. Two GMs with broken door handles. What's your point?
Assuming it *EVER* gets fixed. At this point, if it does get fixed I don't think I'll own the car anymore at that point.At least if it is SW, Tesla can fix it without needing to take car in.
Really? You consider that a "standard" tankless water heater? That requires a 240V 300A circuit, which is twice the entire electrical supply of my house. Here's from the description of it:Furthermore let's use a real world example, a standard electric tankless heater you might pick up at home depot. 36kW of draw,
"One of the most powerful electric tankless water heaters available today"
Most of the ones at Home Depot are 3.5kW, 6kW, 11kW, 13kW, 22kW, 24kW, 27kW, and then yes, the huge 36kW one. You basically picked the biggest one they have and called it standard, which is pretty funny.
Well, that you think 36kW is a necessary level of heating for the battery pack is the real problem. But you drew that erroneous conclusion from thinking that is a mid-range power level for a water heater.Yeah the problem with my argument is clearly the water heater I picked made out of unobtanium. *THATS* the problem with my argument.
You don't get air until the heating coils are warm--so at least there is no cold air blasting at you when you first turn it on. It's not instant though.Really? So do you get hot air basically instantaneously when turning on the heat in an S/X like you do with a space heater? That's awesome if true.
There's no balancing. It's just slow. Looking at a log from Saturday, starting at ~20F outside only hit full power in the 4th minute of being on. Frankly if it was instantaneous, I'd always skip preheating. I only preheat enough for the heater to ramp to full power.
Try watching the car with something like Remote S, that's refreshing every 9 seconds by default.
Mine definitely does not work like that. The Tesla app will update about every 2 seconds (I also have Remote S) and mine will increase temps at about 1 degree F every 2 seconds. I have watched it do this from temps as low as -20 F. It takes only a couple of minutes for mine to get from well below freezing to 70 F. I do this all the time.
I have a sub-meter on my car's charging circuit and the power will spike right up and only taper after a few minutes when the car has warmed up.
Watch the power consumption, and how long it takes to get to max power. PTC power curve should be the inverse, high instantaneous power, reducing consumption as the core temp rises. Tesla's control algorithm is braindead.
That's what I said.A direct connect PTC acts that way, but the Tesla cabin heater is software controlled for variable power.
Yeah that would be the phrase if it worked poorly in 2014, followed by and update that made it work "optimally" in 2015. Now that it's 2018, it's just crap. Not pulling punches for Tesla.Non-optimally tuned for this use case might be a more accurate description.
Why in the world would it work like that? Is there some physical limitation to how quickly PTC heaters can safely heat up? (It certainly wouldn't be to conserve power for the battery heater since a few kWs it's such small potatoes compared to the drivetrain power draw.)
I thought this was just a myth. Can someone confirm or refute this?
I don't see any way for this to work based on these heating/cooling system diagrams: Tesla Thermal Management System - explanation
