I suspect that regen only on the accelerator was initially chosen by Tesla in order to avoid the complexities of blending regen and friction braking with a high quality brake pedal feel. Blended braking systems at the time of the Roadster and Model S design were available but were not highly refined.Just an FYI, if you have been driving a Volt in L I can tell you that the regen in a Tesla is much more aggressive than even that. That was the first thing I noticed when test driving a Model S. I have been driving my Volt in L for four years now.
I don't know the exact power levels, but roughly speaking, driving the Volt in 'L' splits the available regen between the accelerator and the blended brake pedal. So, maybe up to 30 kW of regen is available using the accelerator pedal and a further 30 kW is available by using the brake pedal. The total regen is thus about 60 kW on both the Tesla models and the Volt.
I suspect the Volt was designed to reach the maximum accelerator pedal regen that would avoid the need to turn on the brake lights in order to simplify that aspect of the design. Additionally, GM already had experience with blended regen on the brake pedal in their earlier Two-Mode hybrid vehicles and they weren't trying to implement $100,000 sports car level brake pedal feel.
The newest generation of blended brakes in the 2016+ Volt (and probably the 2016 Malibu hybrid) is said to have improved blended brake feel although I haven't spent enough time driving it myself to have an opinion. The Volt and Bolt EV also now have a regen brake paddle on the steering wheel (adopted from the ELR) which can engage the full 60 kW of regen braking (and turn on the brake lights) while guaranteeing no friction braking.
Is the S85D or S90D with 200+ kW motor(s) still limited to roughly 60 kW of regen braking?I believe the point made earlier is that there is nothing to 'increase' with regen by pressing the brake pedal. 100% of regen is on the GO pedal.
I'm guessing yes and it's probably because stronger braking based on releasing the accelerator pedal is judged to be too jarring and is judged to be a bad driving experience. It should be possible to do stronger additional hard regen using a blended brake pedal and that would allow more efficient driving for owners that choose to drive with the weaker regen option. It may be that greater than 60 kW regen when the stronger default Tesla regen option is enabled may not recapture that much more total energy for typical drivers making it not worth the effort to implement.
In the Model S I can deal with it 95% with one pedal....
The Bolt EV is said to allow 100% one pedal driving in many situations (in 'L') in that it will bring the car to a complete stop and will apparently automatically hold the car even on a modest incline (presumably using automatically actuated friction brakes). Pressing on the brakes or accelerator will release the automated vehicle hold. I'm looking forward to seeing how well it is implemented.
