This process has been the worst experience with brakes ever on a car in my life. Been working on cars over 25+ years now.....
Here's an update. I bought 3 different power brake bleeders before I found one that wasn't trash and could hold pressure without leaking. Then bled everything with it. Still no air bubbles present. Decided to drive on a private road and activate ABS after pumping the brakes up to gain pressure. Activated ABS 5 times. Next morning, rebled every caliper in the X pattern like Tesla says to do in service manual, then from furthest to nearest master cylinder. 7 times. NO AIR. NO LEAKS. Then finally the cable came in I ordered to use the Tesla Toolbox 3. Went through the procedure bleeding the brakes IAW the method in the service manual. Same problem....... Did it probably 5 more times, same problem.
Running the Stiffness Pressure test in the Toolbox leads to telling me the system should hold 55 bar or you should rebleed again. Continued to do so, but cannot achieve a pressure value above 10. Apparently low limit is 31 and 80 is high pressure liimit. Took off every caliper to inspect for any leakage of brake fluid around the piston seals, everything is dry. Re-tightened all brake line connections just in case. No change. The only change in pressure I can achieve is if I leave the pressure bleeder on and pumped to 28lbs of pressure, even though it's supposed to be with just the cap on. then I can achieve a pressure value of about 12.75 bar. Toolbox 3 says if the value is above 4 There is air in the system, or there is leak in the system..... Well where the **** is it?
Been through atleast 6 L of some Prestone DOT4 brake fluid from autozone. Haven't seen a single air bubble in days of working on the car. Bought a master cylinder online, received it about an hour ago. It's filthy inside the reservoir, and was shipped with no cap so I'm not putting that in my car. Honestly, at this point I'm beyond livid.
I've checked the diagnostics of everything and the car has no errors present, just that my side marker light is receiving a higher voltage value, because I have some aftermarket turn signals...... Anybody got any other ideas? I only have until 2pm tomorrow to continue to use the diagnostic software, and it's hot as hell outside in the keys, so I'm taking a break. Guess I'm gonna miss my alignment appointment I waited 5 weeks for since I have no brakes and can't drive to Miami like that.
