EVCP installation report - UK
OKAY EVCP installed...here is my report!!!
I have a reputation for saying what I think good and bad, so hopefully this review is valuable for the forum.
Tech for energy booked for 8am today 22nd December 2014.
Plan was to install a Rolec 32A EVCP, FREE of charge with a tethered cable and plug.
I went with them because the customer service was good at the initial point, I felt the charge point looked nice and tidy, and because unlike everyone else I could find the install was free, even for a 32A unit.
The engineer arrived at exactly 8am...good start.
He was courteous, polite, and presentable....just as important.
The instal went well, to be honest it was a simple enough install as the fuse unit is on the same wall in my garage as the area I wanted the EVCP installed, however he took the time to hold the unit up against the wall without me asking and making sure I was happy with the position and the route the cable would run.
HE then basically quietly got one with it. He used proper fixings in the cinder block walls, and clearly and calmly got on with it. They also installed a meter which reports back usage via a gsm connection, and proves to us tax payers that this install is in use, and gathers some usage stats. More importantly for me it records how much power I am using so I can claim it back as a business expense and HMRC could happily check it if required.
Once the install was completed, he tested it with a dedicated tester, and also the normal electricians testers, then he tidied up, swept up and then put the rubbish in his van to take away...simply astounding!!! He even took half a box of garden leaves that had blown in.
PROBLEM : once installed I plugged in and a little disappointment appeared as although the car could see it now had 32A...it ramped up to 10A but then stayed there. Rolec are now shut for Christmas, so it was left as a mystery as everything looked as though 32A should flow. Then I had a revelation. Remembering a comment on the forum I remembered that there is some link to the GPS location and the charge current. Indeed I had charged the car here at 10A before using the UMC and when I went back to the car, sure enough I could turn up the current on the charge screen and wow full 32A. So thats one to watch if you have this installed yourself, remember to check the charge current manually in the car if you have charged before.
Here are some photos of the install....
Paul
