> break down the numbers [nrcooled]
These are not the figures that others have previously posted here & the ones I'm working with. So where did you derive each one??
These were derived from my napkin drawings to figure out the ideal fitment for me.
1. Revs/mile since not provided by TM must be calculated by math from tire (inflated) circumference. If the TStore has a loose tire/rim use your tape. Then derate for weight on tire. Probably be easier & more accurate to use industry data for tire size, which is what I did.
Not that concerned about this since the tire and wheel combo will be VERY close to stock circumference. I am looking at a +/- 5% difference which isn't enough impact to have a great effect on my driving or the car.
2. Offset posted here is +40mm, so where did you get your figures?? BMW using identical 5x120 has 42+mm offset, presumably with similar calipers.
My figures, again, come from my napkin drawings. The disclaimer I put at the bottom of my post "Disclaimer: This is not the ideal fitment for wheels but one which I am willing to sacrifice some function for form." is just that. I am looking for a particular style and fitment that isn't the ideal since the ideal would be to just keep the stock wheels/tires. If I am going to change the look of the car I am going to do it to fit my personality and style.
3. BMW center bore is 72.56mm, but you just need to clear that (hub-centric is for sissies). If ModelS has a bigger hub we can just machine it out. But 72.56mm is among the largest center holes used.
The company that will be building my wheels is sending me a test wheel for a fitment check. I'll report back if there is anything crazy but most aftermarket wheels should fit.
