luvnMyTS
Tesla strongly recommends the "EARLY" warning setting.
As far as close calls, the camera in front is the only thing that warns of cars stopped ahead. That camera can only see so far out in front. If you are barreling along a 50-60 miles an hour and coming up on stopped traffic, chances are, if you don't hit the breaks, the car is going to plow into those cars in front. At that speed, the camera cannot see far enough in front to react in time. At 40 miles per hour, it will usually catch it, but still slams on the brakes quite hard.
Then you have to consider possible reasons the camera may not see the car in front when it normally does. Glare from the sun or lights can affect how soon it recognizes stopped traffic ahead.
Bottom line, if you're using auto-pilot on city streets, you probably shouldn't be, but if you are, and you're coming up to stopped traffic, don't even bother testing auto-pilot. Just hit the brakes and slow as you would if you driving without it. It's certainly not efficient for the car to brake so late and not take advantage of regenerative braking. Auto-pilot is ALWAYS going to brake much later than you would or would feel comfortable with in those situations. Get used to just not using it or relying on it in those situations.
Not sure if Tesla can improve the camera's vision to see further out in front? But I have a feeling this will be an issue with auto-pilot as long as the existing hardware is used. I'm sure when 2.0 is released with new hardware, it will be much improved. Until then, don't even bother testing it. You're just wasting your brake pads and being less efficient with no regenerative charge back to the battery in those hard braking stops.
