ThosEM
Space Weatherman
Why do you believe that any of those rated range values are reliable? I am particularly suspicious of rated range close to zero - I suspect that the 'number miles below zero' is one of the most variable elements, on the supposition that the whole reason for having miles below zero is to cover up inaccuracies in the range calculation. And the fully-charged miles is also an estimate based on what the system believes is the battery's health - presumably you are doing your own calculations because you don't trust the rated range (full) to tell you the truth, yet you then factor it into your numbers.
(edit: re-reading this post, sounds a bit aggressive - please read it in the spirit intended of seeking after the best measurement, not attacking yours as such).
I don't believe the rated range numbers, except as a measure of battery charge state, which is why I'm trying to construct a battery capacity estimate that is based only on things we know.
I *think* we know the energy consumption and total energy are pretty good numbers, and so is the distance traveled. The rated range when full and the rated range used could just as well be % of full readings, i.e. 100% and whatever the display shows at the end of the trip, subtracting to get the % used. So my suggestion doesn't assume that rated range (or ideal range) has any relationship to performance, just that they are proportional to battery state of charge.
Does that make sense?
