ewoodrick
So.... Where to look next? Ideas please!!!!
What are the Energy Graphs showing you? What recommendations are they making? Where do they say the power is going?
The classics don't have that in the energy screen, the only way to get an evaluation is via the (newly available) function in the app - I did it once, I have to do it again after it comes back from service.What are the Energy Graphs showing you? What recommendations are they making? Where do they say the power is going?
The weight of the wheels will have minimal impact when driving at steady speeds. What will have an impact is the aero performance of the wheels, which can be huge. It could easily reduce range by 10% or more. (And then put hungry tires on top of that...)That is right in line with the baseline of my X from right after I bought it, when it had factory 20” wheels. The previous owner said he had gotten rid of the 22” wheels (that this loaner has) because the power usage was hurt so much… So I’m wondering how badly MINE is being hurt by having even lighter Tsportline 19” wheels! That change would be all about the wheel weights and I KNOW that the OEM 20” are some heavy buggers.
That sounds like one of the filters may be clogged, either the small cabin one or the large HEPA one.I have noticed that the AC fan in this loaner seems nearly as capable at moving air as in my Model S, where the X at 11 is about like the S at 7 or maybe 8 on the blower speed. Not sure if that means that a blend door is stuck or what...
@geordi - don’t have any specific ideas to offer up but do you have some kinda of data logger (e.g. TeslaFi, stats, etc.)?
As perhaps there may be a clue in comparing data across drives.
For example, while you may see consistently high usage on all drives, you note some subset where it’s particularly high unexpectedly suggesting some characteristic about that subset which is causing/exasperating the problem.
Has your acceleration mode setting changed?First - please do not suggest "just drive slower!" as an answer. Because not one of us bought these to do 50mph on the highway, and that is completely unrealistic in our modern society. It's likely to get someone run off the road. I have not changed my driving style from one vehicle to the next, and my highway cruising is long distances over frequently traveled routes, so I can SEE where the power usage has changed over time. It actually was lower when it was COLDER.
I'm asking for suggestions / places to look / things to try, and if there's anything I can check with ScanMyTesla or Tessie, I'd be happy to.
2016 X 90D. Battery currently showing 14.3% degradation, 224 rated miles at 100%, Tessie thinks the real world is 180. ACTUAL is more like 140. So there's either a mismatch in the BMS or there's something else going on. Cruising highway speed FLAT LAND (Florida, Georgia, SC, NC) is pushing 500 wh/mi. No that should NOT be that high. Previously driving the same route, power usage right after I bought this X at the same speed was around 375.
I've seen north of 500 wh/mi while towing (ok, that makes sense) but on the same trip in the plains, with a tailwind, was seeing 650. So this feels like something that is changing or turning itself on and off rather than something mechanical. Not towing right now, I'm seeing 470-500.
I've had the half shafts replaced, changed to a set of Tsportline wheels (and I can feel that they are definitely lighter than the stock setup) with slightly narrower tires (255) that are the same diameter outside as the 20" wheel setup. No extra electrical loads inside, no inverter (so that's all ruled out). AC is on, refrigerant load is exactly correct according to the sticker. ~25 and ~200 for refrigerant pressure with the system on. Ohmmu battery now.
Virtual support hasn't been terribly helpful, suggesting that I needed to replace the 12v battery and the coolant pump - but no mention of which pump, and there are no errors for anything there. The only errors I have seen are related to the falcon door calibration, an RCCM actuator, PresSnsDis (climate pressure sensor?) and now a new one that it is "unable to charge" on AC, when it still is charging just fine.
That unable to charge message (CHG_f018) started right after replacing the 12v battery, so maybe having everything powered off made it detect it. I swapped the 12v batteries around and that error is still there, and it's only been for the last few days. So I don't think that's related.
Wouldn't worry about it. Yes, its recommended not to vent but this is why everyone switched to R134a (safe for atmosphere) vs R22Or vented although you aren't supposed to do that... even though we all know it happens.
I don't worry about it, and I also know that the cans of "air duster" are exactly the same stuff - R134a. But the requirements do say that even 134a is supposed to be recovered rather than vented. I think it is just to make the process more expensive.Wouldn't worry about it. Yes, its recommended not to vent but this is why everyone switched to R134a (safe for atmosphere) vs R22
Can't control things like accidents and leaks...
My bad, meant R12R22 was never in an automotive system
