Mark E
Is was somewhat expensive at my place - due to to the wire between the meter box and the overhead to the house being to thin (antique standards). The fuse on the overhead might have been only 32 or 40 or 50 amps. So that cable had to be replaced. However in order to do that, the entire meter box (which was based on antiquated standards) had to be upgraded or AusNet would have refused to reconnect the power. So it cost $787 to wire the charger, plus $1,939.44 for the sparky and $727.36 for AusNet to come and disconnect and reconnect the power. Much less then $10,000 quoted by the above article, still somewhat impressive.
I spent quite a bit to get the charger installed, but only because the sparky found a few things that weren't up to code that needed to be rectified. In all reality that would have happened without the car if I had him inspect the house. In conversations with him about the state of many houses wiring, its pretty common that there are lots of issues - especially with older houses. Many of these were never wired up for air-conditioning etc etc and in some cases the meter board has been upgraded without doing anything about the feed from the street, so it's antiquated, overloaded and a huge fire risk before the EV is added.
