Started having intermittent trunk release issues so I'm taking the Thanksgiving break to do some maintenance. Some questions...
I was attempting to pull these out into the trunk. Should I be pushing them out of the trunk? Presumably, also you'll need to drop the lower pan to retrieve them for reattachment, correct?There are three 8MM bolts (and fender washers so have a magnet handy, behind the rubber knock outs.
Does someone have a photo of what the cable adjusters look like? My passenger side is the one that needs adjusting so hopefully it's not too hard to reach. Or is it better to just remove the bumper completely like @MLAUTO recommended?From the drivers side on the inside of the rear bumper I could see a cover 1/4 the way from the latch in the cable run. I removed that cover and low and be hold, an adjustment barrel. So I ended up loosening the cable giving it more slack. I then found where the passenger side cable adjustment was, behind the Tesla name in the rear. You have to get to it from where the actuator sits. Its a pain but doable. I then loosened that one. Closed the trunk. Tried opening it via the inside trunk release, and waaa-Laaa, the drivers side popped open but not the passenger side, so trial & error, played with the barrel. And got both working.
Didn't realize the key remote requires tuning! Anyone have info on how to do this?Next I had to tune the Key remote. For some reason that behavior is a little different, but I ended up finding a sweet spot for that which worked for both trunk release mechanisms. And the key just worked!
