supratachophobia
BMS reads 4kw. It could very well be 2kw in the smaller batteries (60/70kw).Is it 4 kWh though? last thing I read from @wk057 is that it ended up being 2 kWh? Or did I not understand that?
I actually spoke with an ex-Tesla engineer who actually worked on the BMS software early on. He explained that the 4 kWh "buffer" doesn't mean what we think it means. It was actually a kludge built in to smooth the range calculation, and to make sure you actually could hit zero miles consistently without getting stranded. On average, the actual capacity "buffer" is 2 kWh, so the code was written so that a 4 kWh window was used and scaled along with the SoC as the car discharged, adjusted and calibrated as possible based on other measurements. This was to ensure that the range calculation would never adjust abruptly, and should never (rarely) run out of capacity while rated miles were > 0. TL;DR: The actual capacity left on the table by the value of the "buffer" is targeted by the BMS to be half that much.
It sounds like you are using scan my Tesla. Could you post the data?Another reason why you'll never get rated range: Raven edition
I don't recall my previous car doing this, and I can't check it since I sold it. However I've observed the following:
When charging, the car counts each mile added as 284 Wh, seemingly regardless of SoC.
Measuring charging efficiency by comparing energy added to power at the outlet I'm computing 92-93% efficiency, depending on input power.
When you look at what the BMS is reporting for energy either in nominal or usable kWh, it's significantly less. 94.6% of the value reported in the API. Total charging efficiency becomes ~86.4%
If I divide nominal kWh by rated miles at 100%, I get 284 Wh/mi
If I divide nominal kWh by rated miles at 54%, I get 296 Wh/mi
If I divide usable kWh by rated miles between 54-100%, I get ~292 Wh/mi
So. many. fudge. factors.
Yes, which data?It sounds like you are using scan my Tesla. Could you post the data?
Do you have the rated miles that go with that? I think it's below the regen total.
344Do you have the rated miles that go with that? I think it's below the regen total.
Ok, thanks! I will try to absorb some of that before commenting.
I mentioned this a lot previously. The "EPA" or dash rated range calculation is using a differen WPM depending on what SOC it's currently at. Soooo shady.....Another reason why you'll never get rated range: Raven edition
You'll have to refresh my memory. Do you mean marketing material? I posted a pic last year of a 100% to 2% trip where I graphed the BMS data using a couple thousand data points. The consumption was just about as linear as I could make it (freeway trip, 254 miles), but the real kicker is the "lying" equation Tesla is dynamically changing as you approach zero is also linear. So that tells us it's not accidental.So the early charts posted that showed linear drop aren’t accurate, or it changed since then?
Edit: here we go: I think my car is lying to me...
That’s the linear black line I was thinking of. So you are sticking with that? It’s linear. That means it’s consistent.
Every X Watts you consume the black line ticks down consistently Y miles. Right?
e.g. if your internal car constant rated consumption is 219 Wh/mi, and the display ticks down at 210 Wh/mi, they save up 9 Wh/mi for the energy buffer to adjust for errors, if any, and to give you miles below zero with that energy left over if not used for errors.
No, the fudge factor is linear. In other words, as it approaches zero they incrementally adjust the wpm calculation the same amount until they hide the 4kw you can't use (but they said you could use at the beginning). That's why it's so insidious, because it's on purpose. If it was "random" we'd chalk it up to a consumption miscalculation or an efficiency loss like you said.
eg. at 100%, they use 290wpm, but at 75% they are using 285wpm, 50% it's 280wpm, and so on and so forth until you get you "zero" and they are using something like 265 or 270, which of course is considerably optimistic and you'd have to use some serious hyper-miling to achieve it. BTW, those wpm numbers aren't exact, I'd have to check the spreadsheet to see what they are exactly.
The anti-bricking buffer is not included in the BMS reported pack capacity or remaining charge. At this time at 100% I get 203 rated miles. As far as kWh I have 60.5 at 100%, but that includes the 3.8 kWh below the zero point. Therefore, I have 56.7 kWh from 100% to 0% (on the dashboard) and 3.8 kWh from 0% to true zero (BMS zero).
By "wpm" you mean Wh/mi? If the black line is linear, then it ticks down at a constant Wh/mi, right? That's the slope of the line.
Where in the chart are you seeing different Wh/mi ? Are you still open to sharing the source data? I wouldn't mind analyzing it.
Have you ever driven beyond 0 to see if it's actually at shut-off when it shows 0, or if any/alll of the range that's "lost" is actually still driveable before it shuts off at the anti-brick level?
e.g. like post #187 here:
Calculate usable battery capacity based on rated miles values
There's pictures there showing the energy chart going to -7% and using that "last" ~4 kWh of energy, implying that the anti-bricking buffer of ~4 kWh is completely hidden and below that.
e.g. 100% -> 0% = most of your actual usable capacity, 0% -> -5 to -8% = the remaining portion of your usable capacity that you can use to get total EPA range, and beyond that is the actual anti-bricking portion that's not shown anywhere and internally counted as "true zero" for which you cannot go below.
I can send you the Excel file, no problem. As for the wpm, yes, that is what the graph is showing. Changes to what the BMS is using to get remaining range. They should use the EPA number the whole way down. They don't.
As for brick protection, I don't know any of this -7% nonsense. All I know is that zero should should be what the car tells you at 100% minus what you've driven (at EPA consumption). If Tesla wants to give you an extra 4kw for the idiots out there (at such low SOC, the car is unsafe, not enough reliable power), then that's their business.
