SteveS0353
It's just an idea, with little proof so far - it could be quite incorrect.
Keep in mind, the high voltage contactors are fairly similar in design to a relay - 12V power is going to an electromagnet that holds the contactor closed while a spring tries to push it open.
Thus, what I was suggesting is that if the car's 12V voltage becomes low or has a lot of ripple in the voltage from an overloaded DC-DC converter, it could cause the contactor to not stay fully closed, possibly leading to bits of sparking and then the overheating and failure suggested above.
I'm pretty sure what I just described can happen with the types of pieces the Model S has in its system. I have no idea if that is what is actually happening to the cars experiencing the failures.
Walter
The contactor may be a latched permanent magnet type, magnetically held closed with a spring to open the contacts on detection of a failure. That won't take power from 12V to keep it closed. The failure mode is thermal -- too much heat in the contacts, heats a bimetallic strip which applies force to oppose the magnet, and the spring flips the contacts open.
The reported clunk is not so much the movement of the contact arm as it is the arc -- think of lightening and a thunderclap. Breaking a circuit which has hundreds of amps flowing is not simple. Mechanical contacts is the only reliable way to ensure an open circuit. A solid state relay can fail short circuit.
