Hans -
Any updates on the Pebble App? I'd like to be a beta tester!!
Aaron
I had no trouble getting teslams setup on a ReadyNAS device running linux. It is the only "always on" device on my home network.
I have two Raspberry Pis sitting at home, waiting for me to have the time to get all this up and running. I am hoping to simply release an image that people can use and plug those little babies into their home network.Do you have any other suggestions on possible appliance type solutions? I thought about a hosted solution, but that seems a bit overkill and expensive since I am assuming you would need a custom server (VM or hardware based).
Hans / Dirk, awesome work on this package. Been using it for about 3 weeks now running both on a Ubuntu VPS and home windows machine.
I'm running into a strange problem: big chunks of my tracking data disappear eventhough my streaming.js is running 24/7 (albeit with the sleep mode -z enabled).
Symptoms:
- When looking at the energy data or map, chunks of my route will be missing (I checked in the original mongo data and there are no entries for that timeperiod in the db)
- Example of a route with about 20 minutes of data missing in the middle of the route (note I'm driving from the center out to the ring road, but the track suddenly jumps to the ring road):
Eliminated possible causes / performed tests:
- problem occurs both with 0.8.1 and 0.8.4 versions
- problem occurs both on windows and Ubuntu instances. Interestingly, sometimes chunk is missing in either one (changes which one), sometimes in both.
- chunks are not only missing at beginning of trip (possible sleep mode delay) but also mid trip so unlikely car is truly asleep
- chunks are also missing when 3G connection is fine: they show up in the other instance and by coincidence in some cases I was checking things online in the exact period the data is missing.
To do - but hesitant:
- Starting tonight I'm going to run the streaming.js without sleep mode to see if I have the same problem. This is no fix however as it will likely increase the vampire draw of my car and points to an issue with the sleepmode.
Is anyone else experiencing these problems when running in sleep mode? Does anyone have an idea on how to fix this or diagnose it further?
Thanks for any help!
The problem is that when you collect telemetry from the car, it will never fall asleep. To get around that major limitation I implemented a concept called a "nap".
Once the car falls asleep it can be monitored to see if it ever wakes up again and goes 'online'. It can do this with the one and only REST API call that doesn't wake the car, and will tell the app what state the car is in (asleep, waking, or online).
Could you set certain days/times when a "nap" is allowed? I have a fairly predictable driving pattern M-F, so if I could restrict naps (and thus car sleep) to certain hours of the day, I could get some of the benefits of sleep mode without sacrificing logging integrity.
