sleepyhead
Again, I would have to say check your units and how you are sampling them. In your case, you are trying to sample for cars six months ago.
The first thing is you can't just subtract the number of new cars from that number, because there are also used cars that were removed from/added to (for example putting a non-operational vehicle back on) the road during that six month period which will skew the numbers. The most accurate way to do this is to use the population size of the vehicles sampled to arrive at that 150k number (keeps numbers consistent). The reason the ICE numbers tend to be accurate is the sample is large enough and ICE cars on the road does not vary too much per year.
Second of all (and this is more important), is if you do sample from six months ago, you also have to consistently sample the number of fires from six months ago and that was 0 for the Model S, so that puts Tesla at 0 chance of fire (which is meaningless).
Put another way:
6 months ago - 0 fires per year / 12k Model S
Now - 3 fires per year / 25k Model S
If you assume same risk of fire per vehicle you would expect:
Future - 6 fires per year / 50k Model S
Future - 12 fires per year / 100k Model S (and so on)
You can't arbitrarily pick fires that happened 6 months later with a 2x larger population for Tesla and then limit the sample size to 6 months before (when 0 fires happened). The math just doesn't work that way (you can only do that for ICE because total cars on the road does not vary much per year).
Yes, there is a side point that the Model S volume and number of measured fires are too low to say there's statistical relevancy, but that's a different point.
Like I said before, I don't have time to debate this subject anymore. I know that my math is correct and I am sure of that. Maybe I didn't explain it correctly.
Elon is comparing apples to oranges when saying 5x less likely to catch fire. I am "annualizing" Teslas in order to create an apples to apples comparison, which leads to ~2.5x-3x less likely, using the same (flawed) methodology that Elon used.
I was just trying to show that Elon was misleading with the math he did. That is all.
