Hey everyone I'm the new guy here and I'm not very smart when it comes to Ev's. In fact I bought a 21' Tesla model 3 SR+ and has yet to move under its own power If that says anything. I have spent 2 months trying to work on this thing and just keep getting hurdle after hurdle. Here's the deal with it It will not let me use any high voltage from the battery, not to drive, not to charge and not for AC which is typical of the HVIL system knowing there's a problem. I have two main error codes in the BMS system which are BMS_a107 and BMS_a171. Basically in testing the two sides of my pack One test at 179 volts and the other side test at 178 volts and I believe the one error is because it has mismatched power between the packs. I was going to do a battery health test to drain everything and let the BMS essentially equalize out the parts however I need under 50% SOC for that to happen and I am at 51.5% go figure. Given that I can't charge it I thought maybe I can manually charge half of the battery to 179 so it would at least be equal but I don't know what kind of charger or variable power supply I would use to do that. Or, somehow drain the one side to match. The kicker is and for those who are going to say you should bring this to the SC, I already did and because the dummies that transported it used a forklift and put a small dent in the bottom of the battery that I never noticed, Tesla did notice and now they will not touch it until I replace a battery which I'm not going to do if possible. Long story short I'm currently upside down in this car and I'm almost at the point where I could have bought a new one at the same cost and I've had a very bad experience and I just want to get this thing to work for a first time EV to test out to see if I like it before ordering the stupid cybertruck that may never come out or maybe it will I don't know. Any and all help is appreciated thanks in advance
