felixtb
RsEU502,Sp+14274,XpEUSig4
I'm sure the reason the adapter cable is so long is to avoid putting too much stress/torque on the inlet mounting cup. If that gets popped off the body panel, it's a real pain to get a replacement glued back on in the right.
I'm sure you are right Tom. however, if the cord was about 10 to 15" then it could be pre bent to hang closely down the side of the car with a small microfiber protection on the J1772 side to protect against scratches. it could even have a small hanger that fit into the bottom of the connector well for extra support. this should minimize the torque stress on the car inlet and not having the connector lying on the ground. and it would fit in the depression in the trunk floor....... it would have been a more elegant solution. but maybe this can be done by cutting the cable and mounting a new J1772 or mennekes inlet on the shorter cable and then using the left over for a Mennekes <> J1772 converter..........
