This is a very good presentation. I like the chart. I'm not sure where you are getting the Wh/mile figures. I'm sure you addressed that in earlier posts, and they seem to scale with simple ratios of kWh battery to miles range.
There is still enough ambiguity here that critics can dispute it all they want. But Tesla has a long history of dropping clues here and there that some are able to piece together and see where the company is headed while others just want to dismiss. In time, these things will become clear. I suspect that Tesla will launch the Model X with 70 and 100 packs, and it will be clearer that we are dealing with higher density cell, unless the 100 pack are bulkier and heavier.
So let's just weight and see. I know all I need to know to hold my shares. The risk here is to shorts if they assume that Tesla has not developed higher density batteries.
The Wh/mile figures come from the EPA range divided by usable capacity of the battery. Usable capacity is taken to be 95% of the nominal capacity based on the statement from the Manual that 5% is reserved for "bricking" protection, as explained here.
The bottom line is that chart shows that there was no increase in energy consumption of 70D as compared to 60 to account for the increased weight of the battery pack. I do not see how is this possible unless the weight of the 60 and 70D packs is approximately the same. This, in turn, would indicate that 70D pack contains next generation cells with higher volumetric and gravimetric energy density.
Tesla also seem to take highly unusual step of ***lowering*** their EPA overall range from 245 to 240. The EPA city/highway ranges shown in InsideEVs article, however, were not lowered, and EPA formula of 45% citi, 55% highway combined range results in 245 miles, not 240: 0.45*242.8+0.55*246.4=245. I think that TM decided to "voluntarily lower" the range to 240 because they want more differentiation between 70D and 85D, and, perhaps, do not want to "show all their cards" regarding the next generation cells. They clearly do not want to telegraph that 85D is likely to become 100D some time this year after launching MX because it might result in some people delaying their orders until that happens.
EPA data from the InsideEVs article linked above (with my highlights):
- - - Updated - - -
Perhaps someone has some info on the weight of these cars that may shed some light. For the time being, I remain optimistic that Tesla does have a slightly higher density cell. They are due for this and would really want to try this out before putting it in the Model X.
We will have to rely on some of the Automobile publications to provide weight information as part of their reviews, or... wait until TM updates their Manual. It contains a lot information, but very few people seem to use it as a source. For example there is long lived myth that 60 and 85 battery packs weigh the same because 60 pack uses dummy cells in empty spots. This can not be true because according to the Manual cars with 60kWh pack weigh 223 lbs less than cars with85kWh pack. This squares with the approximate weight of each cell of 45.4g (Panasonic NCR1865A) plus some additional savings in casing of the modules, cooling, etc.
