charliepmayer
I could not get the charger in the parking garage downtown Kerrville to activate. Don't know why.
This is old info: 15 months or so, anybody have an update?
Has anyone verified that they actually have electricity in Ft.Stockton or Pecos?I could not get the charger in the parking garage downtown Kerrville to activate. Don't know why.
I have used it a couple of times with no problem, but it has been a year since I used it last. It is pretty low power (215V 30a.) and is within easy round trip to my house, so no real need.I could not get the charger in the parking garage downtown Kerrville to activate. Don't know why.
This is the same type of behavior the supercharger in Midland exhibited when I was there. El Paso has been the only supercharger that works consistently well in West Texas........and it only gets worse.
I’ve been stuck in Ozona this afternoon with slow SC pedestals. Charge starts at 112kW but quickly tapers to 35-20 kW. This is a 100kWh battery at 21%. I have now reported this SC three times and it still not fixed. One pedestal here is continually ICEd. Of the remaining pedestals the only one that will sustain a high charge rate is 1A - the one reserved for disabled access.
If you are heading west you will need pretty close to 100% to get to VanHorn or desinations south of Balmorhea.
Will check Fort Stockton after I finish charging here in Ozona - perhaps by midnight if I am lucky.
Ozona air temp was 117 degrees - might have something to do with it. Or not.
Wow, you sir, are either a genius with American Indian Medicine man spirit, or alternatively, the crazy germophobe guy at the supercharger talking to himself whilst he pours evian bottled water on the water handle..... unfortunately, both cannot simultaneously be true.I do not know if it helps, but as soon as I plug in with HIGH Temps I wrap the handle with a Microfiber cloth that I carry around for this. First I wet it good, wrap it around the handle, then slowly add more water until it drips off. Then every 5 or 10 minutes I will add more water. It does keep the handle cooler so maybe it allows the higher charge rate. Would be interesting to check when you find the rate go from 112 kW down to 35-20kW. Wet the cloth, disconnect the handle, wrap it, then plug back in and keep the cloth wet. Let us know if it works.
I have only a 75kWh battery so it starts at 96kW or so, but it seems to hold a higher charge until I am ready to go, even in 115*f temp.
I'm not sure my brain would allow my hand to pour water on an electrical connection. Perfectly safe, I'm sure. Or is that plug still in beta? I'll go check the manual...Wow, you sir, are either a genius with American Indian Medicine man spirit, or alternatively, the crazy germophobe guy at the supercharger talking to himself whilst he pours evian bottled water on the water handle..... unfortunately, both cannot simultaneously be true.
Use distilled water. It is a poor conductor. Would you not supercharge in the rain?
I looked at getting a custom fortune cookie made, but they only allow 70 characters. It cut off "in the rain", so the profundity was lost.Dang, that was like a riddle from the show Kung Fu
Would you not ...super?
