S4WRXTTCS
The biggest question for me is: Can Smart Summon be used from a meaningful distance non-stupidly?
Because the way Smart Summon is set up, the driver responsible for the drive is always unable to see — from a distance — part of what is going on around the car. This in itself is a form stupidity, if performed, because you should always have full awareness of what is happening around your car when it is moving. Yet the way Smart Summon is set up, if you are standing at a distance, you will not see the other side of your car nor will you see through any obstacles blocking the line of sight...
...and what’s worse, there is no really good solution to this. Vigilance doesn’t help because you simply can’t see from a distance through your car and probably not around all other obstacles either. The extra blindspots this setup introduces are greatly increased compared to any normal driving situations. The only thing that helps is removing the responsible driver from the equation, or by being close to the car and moving around to monitor its movement. Perhaps camera views on the phone could help.
I agree, and in fact I've been testing Smart Summons from the drivers seat because its the only good way I know to do so.
But, my position is likely obviously because I was arguing well before the release of Smart Summon that it wouldn't work because of the lack of 360 degree down facing camera.
As to the line of sight? It really reminds me of drones where the FAA rule is you have to be in line of sight, but then the range on the drone controller is in MILES. It's basically this tiny dot in the sky, and there is NO WAY people can actually see the drone.
Basically there is a huge disconnect between what you're supposed to do, and reality.
In any case where I've been testing it I can see the car the entire way along with the having plenty of warning if another car enters the testing area.
I decided to jump in the car since it was getting too close to a curb for comfort, and the latency in the dead mans switch meant I had less buffer than I wanted. It's a $60K+ car so I'm going to watch over it like a hawk. I just don't get people who have no fear about their expensive car hitting something.
As to safety they can certainly add a level of safety by requiring the pedestrian noise maker for Summon. Of course that would require adding it to cars made before September of this year (or whenever they made that change). Lots of owners would be resistant to that as lots of owners absolutely hate the noise maker.
But, that would allow the car to make a noise before backing up, and thereby alerting any pedestrian.
