yes pretty soon I - will - be - typing - like - this :biggrin:
also note wk data was not done at high temperature where complex impedance is much lower. wk is well meaning and again I agree in NO WAY can the car be measured to produce 691HP on a dyno, but it appears he has no experience in pulse power system design using lithium cells (which are actually all hybrid capacitors in some respects).
Don't you all have day jobs?
I feel like this has become my day job.
And my night job, my middle of the night job, my weekend job...
It is Saturday!!!
Respect to those how have put so much thought into this topic as it is quite epic.
I follow, but just don't see how I could see this to be a bigger issue. Maybe I'll feel differently if my X doesn't perform as I expect it to.
If you start with "if (false) { ... }" or "if (suspect_hypothesis) { ... }" then the rest of the statement could be all kinds of fantasy that really is just intellectual, um, "focus on self". Sorry, it's an engineering / first principles thing.
Also, words like "majority" are often used to attempt to bolster an argument and force people into sides. Generally, I find this counterproductive as it creates conflict and distracts from the merits of the discussion.
Still have you on ignore, but someone PM'd me about this post.
First: lol.
Next: I've had over a dozen test cases running for the past several months doing cycle testing of Model S cells under various conditions. The internal impedance is nearly constant across all temperature ranges I've tested, right up until just before the cell explodes... which doesn't seem like a useful temperature for use in the Model S. One of my tests is one of my own design and is discharging and charging the cell as fast as possible while maintaining a constant cell temperature about 15C below the temperature where it's guaranteed to have a thermal event. I also am running that same test at a few other constant cell temperatures. Results have been pretty interesting and I plan on doing a write up on the results of all of my testing sometime in the next couple of months when I have enough data from some of the slower tests to better confirm the results. All using custom test equipment I designed and built specifically for testing these 18650 cells with high accuracy (and in pairs to have confirmation of the results).
Suffice it to say, under no conditions that I've tested does the internal impedance vary enough to make any notable difference in power output, good or bad. Even under maximum draw (basically a short circuit) at the millisecond level the cells do not deviate from my predicted results within a reasonable margin of error (+/- 1%). Therefore my graph represents reality, at the pack level, within +/- 1%.
Further, you have no knowledge of my background and expertise, so do not make such claims. I can, however, make the claim that you have no experience testing the Model S cells, the P85D power output, or anything directly factually related to this particular issue.
WK, please say a bit more about your chart. Is this your calculation from measurements you made on cells? Your text implied they are P85D cells. Should the curves on cells with the P90D chemistry be higher? Either way, with 600 HP for 100% SoC at 1500 Amps, that would seem to have positive implications for further improvements in performance for both cars.More misinformation. The P85D battery is incapable of putting out 515kW.
Wrong. The internal impedance does vary with temperature enough to make a very noticeable difference in pulse/burst power.
Not enough of a difference to measure 691HP on a dyno, but that is besides the point.
Why else would the Ludicrous cars have a MAX BATTERY POWER setting that heats the cells!
I do have a custom pack made from Tesla cells
and yes they perform best when hot (as any EV drag racer knows).
